Who has played around feeding a DAX IQ output into PowerSDR?
Duane N9DG
Spent some time this evening playing around with using a DAX IQ output into a PowerSDR session for RX use. It basically works, but found a few issues:
1. I/Q are inverted – so for example to hear 40M LSB in PowerSDR you must use USB, and of course the spectrum frequency display is also inverted. Unfortunately I do not see a way to swap left/right (I/Q) on the DAX set up side, and PowerSDR does not allow that either from what I can tell. HDSDR does allow this which has proven handy.
2. Even though I have DAX set up for 192 kHz there is a distinct roll-off of the signals at about 160 kHz of spectrum width. So my impressions are that the is the nature of the “filtering” to generate DAX I/Q output.
3. The signal and noise spectrum levels seen in PowerSDR seem to be about 40 dB “louder” than they should be. So that makes me wonder, is the DAX I/Q output 16 or 24 bits? I suspect that PowerSDR is expecting that a 192 kHz “unsupported” sound card to be 24 bits.
Why do this? Because it is possible. And I just want to see just how much of this kind of functionality is actually all possible. Though I do also want to peak at some signal processing and recovered audio traits of SmartSDR vs. PowerSDR vs. various other I/Q “sound card” SDR programs that are out there. And to do so simultaneously with each of those different SDR programs being fed from the 6K hardware.
Duane, I think that you'll get more interesting results, if you feed DAX I/Q into a
good spectrum analyzer program.
I like DL4YHF's SpecLab (and his other programs):
http://www.qsl.net/dl4yhf/spectra1.html
You'll get exact measurement and time markers and a plethora of other
possibilities out of this.
This is a 96k spectrum of the 20m-band here at Karlsruhe with the center
in the digimode sector at 14.076 (ignore the VFO setting, as CAT is
not supported - and unecessary - for the Flex radios):
I also use this program to receive and measure VLF stations like the
Alexanderson alternator at 17,2kHz with my SDR-IQ, which is directly
supported.
PowerSDR is - by itself - a great program for my older Flex radios, but methinks
not a great program for signal detection and measurement.
73, Alex-DH2ID1 -
I had once thought about feeding DAX IQ into HDSDR. It would be nice to use HDSDR's recording feature but it's not possible unless someone comes up with a external .dll for the program?? I don't believe there is one out there anywhere?
Cal/N3CAL0 -
Cal, I run HDSDR here with OmniRig, works absolutely fine, CAT and
PTT works, start up with HamLib, using ExtIO_HamLib.dll
OmniRig setup:
Notice that I have set up COM8, that is an extra port created in
SmartCAT. All extra programs beside the main CAT program
(In this case MiniDeluxe) should run on extra CAT ports:
I work 99,99% digital modes: PSK, JT, RTTY, Olivia, MFSK, **** and Domino
on HF (and CW also, which is a semi-digital mode) and D-Star and FDV on
HF and VHF.
73, Alex DH2ID1 -
Thanks for the info Alex! I'll have to give it a try.
73 de Cal/N3CAL0 -
Yes, this is a known issue with PowerSDR. The I/Q channels were swapped from the de facto standard in PowerSDR due to the channel being swapped with the FLEX-5000.
This is normal.
SmartSDR is set for 192k @ 24-bit. PowerSDR will be set to how the VAC cable is configured.
- 319 Community Topics
- 576 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 157 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 125 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 103 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 132 Contesting
- 699 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 923 Third-Party Software
