Who has played around feeding a DAX IQ output into PowerSDR?
edited March 2017 in SmartSDR for Windows
Spent some time this evening playing around with using a DAX IQ output into a PowerSDR session for RX use. It basically works, but found a few issues:
1. I/Q are inverted – so for example to hear 40M LSB in PowerSDR you must use USB, and of course the spectrum frequency display is also inverted. Unfortunately I do not see a way to swap left/right (I/Q) on the DAX set up side, and PowerSDR does not allow that either from what I can tell. HDSDR does allow this which has proven handy.
2. Even though I have DAX set up for 192 kHz there is a distinct roll-off of the signals at about 160 kHz of spectrum width. So my impressions are that the is the nature of the “filtering” to generate DAX I/Q output.
3. The signal and noise spectrum levels seen in PowerSDR seem to be about 40 dB “louder” than they should be. So that makes me wonder, is the DAX I/Q output 16 or 24 bits? I suspect that PowerSDR is expecting that a 192 kHz “unsupported” sound card to be 24 bits.
Why do this? Because it is possible. And I just want to see just how much of this kind of functionality is actually all possible. Though I do also want to peak at some signal processing and recovered audio traits of SmartSDR vs. PowerSDR vs. various other I/Q “sound card” SDR programs that are out there. And to do so simultaneously with each of those different SDR programs being fed from the 6K hardware.
Welcome!
  • Member ✭✭✭
    edited March 2017
    Duane, I think that you'll get more interesting results, if you feed DAX I/Q into a
    good spectrum analyzer program.
    I like DL4YHF's SpecLab (and his other programs):
    http://www.qsl.net/dl4yhf/spectra1.html
    You'll get exact measurement and time markers and a plethora of other
    possibilities out of this.
    This is a 96k spectrum of the 20m-band here at Karlsruhe with the center
    in the digimode sector at 14.076 (ignore the VFO setting, as CAT is
    not supported - and unecessary - for the Flex radios):
    I also use this program to receive and measure VLF stations like the
    Alexanderson alternator at 17,2kHz with my SDR-IQ, which is directly
    supported.
    PowerSDR is - by itself - a great program for my older Flex radios, but methinks
    not a great program for signal detection and measurement.
    73, Alex-DH2ID
  • edited March 2017
    I had once thought about feeding DAX IQ into HDSDR.  It would be nice to use HDSDR's recording feature but it's not possible unless someone comes up with a external .dll for the program??  I don't believe there is one out there anywhere?
    Cal/N3CAL
  • Member ✭✭✭
    edited December 2016
    Cal, I run HDSDR here with OmniRig, works absolutely fine, CAT and
    PTT works, start up with HamLib, using ExtIO_HamLib.dll
    OmniRig setup:
    Notice that I have set up COM8, that is an extra port created in
    SmartCAT. All extra programs beside the main CAT program
    (In this case MiniDeluxe) should run on extra CAT ports:
    I work 99,99% digital modes: PSK, JT, RTTY, Olivia, MFSK, **** and Domino
    on HF (and CW also, which is a semi-digital mode) and D-Star and FDV on
    HF and VHF.
    73, Alex DH2ID
  • edited November 2015
    Thanks for the info Alex!  I'll have to give it a try.
    73 de Cal/N3CAL
  • Administrator, FlexRadio Employee admin
    edited March 2017
    Yes, this is a known issue with PowerSDR.  The I/Q channels were swapped from the de facto standard in PowerSDR due to the channel being swapped with the FLEX-5000.
    This is normal.
    SmartSDR is set for 192k @ 24-bit.  PowerSDR will be set to how the VAC cable is configured.
