Squelch for All Modes?
Dave, I'm with you on this. It is extremely frustrating when you want a conversation with the vendor and, it seems, everyone but the vendor chimes in. That, I believe, is a flaw in this model, but it is by design. You said something interesting though, that you 'need' to know the answer. I am curious why and perhaps the safest approach is assume it wont and be pleasantly surprised if and when it does.if it is something you need and it doesn't exist there is a question and answer there. The purpose of flexlib is to convert UI actions into the form the radio expects commands in and to reflect actions taken in the radio in the UI. If the basic functionality does not exist in the radio, it cannot be added in flexlib.0
Walt, I guess I need to explain myself. Dave is my best friend. I've known him close to 40 years now. Some of my comment to him was a playful jab. (he knows VB pretty well)
As for UI actions in Flexlib, you are right. BUT, you can combine some to get the desired action.(or close to it)
You can monitor signal strength, have a Slice receiver MUTED until signal strength reaches a pre-set level. Even add a slider control to set the signal level that Un-mutes the Slice receiver(s).
Crude, but it would work. All using existing Flexlib code.
Oh, thanks for responding to my email. Interesting comments!0 -
The squelch used on powerSDR for the 1500/3000/5000 works very nicely. For those not familiar with it, you might want to down load the program and use their simulator. I would assume SmartSDR will follow this lead.0
I added this feature using the FlexLib API just as you described it. Thank you for the inspiration.
I am happy with the result. It works best with stronger signals.0 -
Robert,
Just read your post. I'm glad that worked for you. Do you have it with just the Active Slice, or for all Slices? Active Slice only is pretty easy to do. But, it's a bit more complicated with more than one Slice Receiver. That involves Threading and enumerating all available Slice receiver objects.
Not too hard. But it makes for some fun getting the right events connected with each other! (I'm slowly learning how to do that correctly)
WD5GWY0 -
It is a bit tricky. The secret is when the slice is created, I create a separate SMeterDataReady event for each slice.I use the squelch on/off setting in the radio, but disable the behavior if the radio is in FM mode.
void radio_SliceAdded(Flex.Smoothlake.FlexLib.Slice slice) {
setSliceInfo(slice);
slice.PropertyChanged += Slice_PropertyChanged;
showActive();
switch(slice.Index)
case 0:
slice.SMeterDataReady += Slice1_SMeterDataReady;
SetCheckbox(slice.SquelchOn, checkBox1);
break;
case 1:
slice.SMeterDataReady += Slice2_SMeterDataReady;
SetCheckbox(slice.SquelchOn, checkBox2);
break;
case 2:
slice.SMeterDataReady += Slice3_SMeterDataReady;
SetCheckbox(slice.SquelchOn, checkBox3);
break;
etc...1 -
Count me in on the all-mode squelch feature. I didn't realize how much I missed it until I realized I didn't have it. Variable NR and NB would be nice too.
Have a look at the the level meter mute ( SQ) function in FRStacks.. Works on SSB, AM FDV..
( not DIgital/CW)
AL, K0VM0 -
Has it become acceptable to have to open multiple programs to get just basic functions???
For me its NOT!
K0VM - I have FRStacks running, and Level Meter Mute (SQ) function is checked. Where do I find the squelch slider?
Butch, KF4HR
Mine is on the far right of the window and appears as a vertical slider control - mine shows red were the noise level is - when slider is above that red, then the speaker audio is muted (not the master audio, the slice audio)
You do need to have the window with enough vertical space to show the slider - if I adjust the window so only the active slice appears, the squelch bar will not appear - need to move that program window down a bit. Hope this helps.
Cheers
Thanks Walt. Evidently FRStack is seeing my Flex because I see 5 active slices along the top of the screen, and when I click on MRU bands it shows the band and frequencies, and I see five vertical sliders on the right side of the screen which are all gray (no color) and they slide up and down ok but they have no affect on the volume at all. Evidently I must have something set wrong somewhere. So close... but not there yet! :^)
KF4HR
I rebooted the PC and the squelch sliders work now. Thanks again.
KF4HR
Has it become acceptable ? The real question to ask is has any SDR software on any radio yet been written that includes all the "BASIC" features you demand. Of course, you would first need to enumerate your list of all the Basic features. Much to your surprise you may find that every person has their own list of basic features. For example, my list includes WAN and spots in the GUI as a basic feature I am sure you would be not surprised to find that no software package exists with all the basic features that everyone desires On the other hand Flex has published an API that enables you to add any feature you want from your list of basic features to your radio. So if you are impatient when while Flex works down its list of desired features to add to SSDR, you could always "roll your own"0
I would certainly like to see API capability on the Maestro so we could Roll-You r-Own integrated logger, GUI spots, etc!!!!0
I disagree, Squelch is on EVERY radio I look at, were not talking what only I want, sure I have some personal likes and dislikes.... this is about a standard feature that even a $30 cb radio has and its easy to implement, FR Stacks has it, and yet we have 3 kinds of noise filters...... hey that's great but no squelch, geesh.
As for my preferences:
Memory should not be in a menu item as a sub menu, it should be a choice same as settings profile and help are.....Profile could be under settings.
Also when you select a memory it should goto it then close the window or at least have that as an option.
Many other request are very valid to me and I was very happy with 1500 PSDR, I wonder when squelch was added to it, anyone know????
Thanks to the many whiners in the audience, Flex no longer publishes a Road map of future software developments... So the best anyone can say is that all mode squelch will be added when it is done...whenever that may be....
Flex tends to prioritize feature requests by the number of Likes (rather than whines a feature request gets..)
For me, for example, I have never used Squelch on HF in all the 57+ years I have been a ham...for digital modes and RTTY I just mute the sound and look at the waterfall.... so clearly Squelch is an very low priority item for me...as I do not even consider it a basic feature....
Since this idea only has 13 likes, I suspect that most people do not consider it to be a high priority
and that's why no other radio has a squelch.0
I would not know.... Although I have owned many radios and currently use K3's and IC-7800 in addition to my Flex at the contest station, neither I nor any of my contest buddies have never used squelch. to the best of my knowledge none of us have ever used it for DXing either...So I do not off the top of my head even know which button it was if it exists at all...
I am sure there must probably be a use case for squelch but clearly with only 13 likes its just not that important to most people.
Further as many people have already indicated, Squelch already exists in FRStack for anyone who really needs it ....Probably why Squelch has so few likes...
So it really comes down to the fact that you wish Flex to drop all the higher priority feature development to concentrate on duplicating a low priority feature that already exists because you do not feel it is convenient for you to use the secondary program that has it...0 -
The api Flex has published does not allow you to roll your own functionality into the radio. That level of programming is quite opaque to users. The api that does exist if for people to roll their own UI to existing functionality that already exists inside the radio. The vehicle to accomplish that are a predefined set of text command understood within the radio that can be invoked outbound of the radio itself, based of the user pushing a button or sliding a control or pinching the screen. Users cannot add functionality to the radio beyond that functionality FRS provided in a given release. Similarly users cannot add functionality to their k3 or ic7800 or ts-990 either.
While, yes there is a vehicle for users to suggest ideas for future enhancements it is not clear to me how actively FRS is pulling from that list for any given release. They do, however, have their own internal list of ideas they stopped sharing with the user base for the very reasons you articulated.
It's not clear to me either what percentage of the user base has held their breath waiting on all mode squelch. My assessment, at this point, is if a user or prospect wants a feature not in a given radio but is in another they should get the radio that incorporates the feature(s) they want. I'd give that same advice to an owner or prospective owner of a car or boat or home.0 -
It is clear for a couple people here the all mode squelch is a deal breaker and they are very unhappy. This has been noted for months now and I'm sure Flex is aware of it. I get the feeling if and when we get the feature, witch we already have as many have said, it would be something eles.
I would be willing to bet these guys complaining and saying harsh things would never get ride of their Flexes simply because of the squelch.
For me, I have the Flex 3000 here as well and I see the squelch button but have never used it. I just have not the need for it.1 -
I think though Bill, we all, or most of us, each have our own "pony" we'd like Flex to incorporate. I used the term pony previously to mean that 'gift' we have our individual hearts set on. Those of us who have or had little daughters know what I mean. I am not convinced that is a rational adult expectation. As I said previously, I can't enumerate any previously articulated wish list items in the radio now. That doesn't mean it won't happen just may not have yet.0
It quite often bugs me how some people really pine for something, like squelch, are treated by others who say they don't need it and done use it if they had it.
If some people want it, they want it. We all operate our radios differently and I would say that we could all learn something from others about how they operate theirs.
I used Squelch often enough on my 5000 (and it was an existing embedded feature) that I expected it to be included in SSDR. Oftem while sitting in the shack doing other work and waiting for a net to start or listening to a local repeater or waiting for a sched to come up I would utilize the squelch. Do I use it every day? No! Could is use FRS stack? yes! But it's like a Merida of other features you only use once in a while, but when you need it, you WANT IT!0
Yes I am one of the ones that never use it, but it could be useful for others. I think what bothers me is the tone used by some when things don't happen as fast as they like. Comparing the Flex to a $30.00 radio and all cheap radios have them, and it would be easy to do? when have they done code for SSDR lately? Really? I'm sure Flex knows some want it, just go with the flow....1
Like Bill I too react to the tone of the request rather than its content. Like I said, while I do not use squelch there is probably a use case for it. That is important to some people. It may even be a deal killer, however if they bought a 6000 knowing it did not have all mode squelch then it likely was not such a killer as they make it out to be. Sort of like those people who buy houses next to airports and then complain about the noise. However I also gauge the priority of a request by the number of Likes it has.0
I think Flex does pay attention to the 'Likes'.
There was a marshmallow-throwing session(s) about RTTY filters, and after the people who were interested in having one voted a Like - Flex came along with a very nice RTTY Rx filter. (still waiting for FSK, but hey - I can wait)
Hams can see that baby steps are used to measure programming - just look at all the versions of other popular software, some come out every few months, some every few days.
So there is hope for this type of product design business model, and for those who want squelch, Vote up a LIKE. Want something else - Post it and ask for Likes.
Oh dear - way too early for a pint . . . time to throw the coffee **** in the fire to boil . . .
Cheers0 -
It is never too early for a pint, <ggg>.
I know this is an old topic but I just thought I would let folks know that there is now a better work around.
Mark/AA3RK produces a piece of software called FRStack. It is a great utility that gives you a lot of control over slices, memories, and a bunch of other features. It even gives you the ability to swap slices. A while back Mark added what he calls a "poor man's squelch". It can be found on the "Radios" tab with the title "Meter Level Mute". Originally it only worked on SSB but recently Mark has enabled it for all modes.
This isn't a perfect solution but it actually works pretty good. I can now have 8 slices open - a couple on digital, a couple on SSB net frequencies and one on a CW frequency. There is perfect silence until the squelch is broken. NICE!!!!!
Another great feature FRStack gives us is the ability to scan frequencies in memory banks. You can configure a slice to scan several frequencies. When a signal breaks the squelch level, it will stop and then carry on when the squelch closes. I love this feature for 2 meters. I can scan 2m SSB or a few repeater frequencies. I also use it for 6 meters while waiting for band openings. I have it scanning the most popular SSB frequencies at the lower end of 6m. I can be on 20m working someone or listening to a net and when the squelch breaks on one of the other frequencies I now have the volume set high enough on that slice to clearly hear it.
I patiently waiting for Flex to implement a true multi-mode squelch feature but until that happens, FRStack seems to be a great work around.
3 -
How do we get this to rise to the top? It seems desired features are not systematically surveyed. It all seems to hap hazard to rise to the level of user input or marketing research.
Perhaps there is a survey or polling section here and I haven't found it.0
- 354 Community Topics
- 618 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 25 Aurora
- 219 FLEX-8000 Signature Series
- 924 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 759 Peripherals & Station Integration
- 979 Third-Party Software
