Impossible
clint yates
I have searched low and high...posted on here.here is my conclusion.It is impossible to send your transmit audio to third party software. I challenge anyone to try it...
Monitoring your own transmitted voice doesn't also stream it via DAX ?? if it is (have not tried it) couldn't one setup the third party software to monitor that channel??
I'll have to do some testing0 -
All listed recording devices including DAX have a listen tab. One can forward that audio to any available third party software.0
Just for grins you could setup a second pan adapter/slice on the same frequency turn on FDX then send the audio to a DAX channel and record that using Audacity or some other recorder. Need to turn the RX EQ off on the RX only slice and make sure you don't overload the receiver. As Ken NM9P says TX on the XVTR port.
https://www.youtube.com/watch?v=CzT1qDKKySk
Definitely NOT impossible. Suggest you search this community for my posting on iPad Remote Updated
I have an example of using 3rd party software to listen to TX0 -
Just press MON to monitor your signal (voice/digital) and the audio stream gets
routed to your speaker connected to your FlexRadio. My Bose speaker has a
3,5mm earphone connector.I just route the audio signal from there and view and
record it on a second notebook. 73, Alex DH2ID1 -
could one then also click the "REMOTE" button and send the audio directly to the PC??
Checked my post this no does not work...0 -
That won't work for what I am trying to do.I wish the xmit audio could be broken out with a Dax channel. That wouldake life a lot easier0
The problem is there is no tx audio to forward. Flex has not give u the ability to break out the tx audio from your mic0
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 37 Aurora
- 947 Maestro
- 924 Genius Products
