Exporting all profiles isn't working for me these days...
Roy Laufer
Roy Laufer Member ✭✭
edited May 2017 in SmartSDR for Windows
I have exported all of my profiles in the past, but I haven't done this since early October - for some reason it just seems to get stuck on "exporting" with the .ssdr_cfg stuck at 0!?
Any ideas? (This is SSDR 1.5.1.70 on my Flex 6700).
Yup, I have tried a few PCs, unsuccessfully.
Yup, I "turned it off and then turned it back on" (both PCs and Flex 6700), without change.
  • Tim - W4TME
    edited May 2017
    There may be a corrupted profile hanging things up.  Just try exporting a few global profiles at a time.  The do the TX profiles.  If that works, then do a factory reset and import the profile back into a default database.
  • Roy Laufer
    edited October 2015
    Thanks Tim!
    The problem was in exporting the "Preferences" - that was the stumbling block, and relatively easy to tweak it back into shape!
  • Tim - W4TME
    edited December 2016
    The preferences constitute the band / slice persistence data.  Once you have exported, a factor reset and import should fix you right up.
  • Roy Laufer
    edited October 2015
    It did, indeed!
    I am able to export all my profiles for backup purposes.
    Thanks again!
