Exporting all profiles isn't working for me these days...
Roy Laufer
I have exported all of my profiles in the past, but I haven't done this since early October - for some reason it just seems to get stuck on "exporting" with the .ssdr_cfg stuck at 0!?
Any ideas? (This is SSDR 1.5.1.70 on my Flex 6700).
Yup, I have tried a few PCs, unsuccessfully.
Yup, I "turned it off and then turned it back on" (both PCs and Flex 6700), without change.
There may be a corrupted profile hanging things up. Just try exporting a few global profiles at a time. The do the TX profiles. If that works, then do a factory reset and import the profile back into a default database.
Thanks Tim!
The problem was in exporting the "Preferences" - that was the stumbling block, and relatively easy to tweak it back into shape!0 -
The preferences constitute the band / slice persistence data. Once you have exported, a factor reset and import should fix you right up.
It did, indeed!
I am able to export all my profiles for backup purposes.
Thanks again!0
- 379 Community Topics
- 119 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
