Volume and AGC level display
Vincent Martin - N5ATM
An idea for a small change to SmartSDR.
To my knowledge, the only way to see the actual slice audio level and AGC level is to hover over the slider control. While the indicator on the sliders give you an idea, it would be helpful to see the numbers at a glance without having to use the mouse. I think it would be a good idea to show the numbers constantly, maybe on the left or right side of the respective sliders.
If not a permanent feature, maybe an option?
73 N5ATM
73 N5ATM
2
That's essentially my suggestion of abandoning graphic meter indication altogether. As far as green, yellow, red, for overdriving, change the color of the numeric. One can actually see the amount of screen real estate it would save.0
An option to change from graphic to numerical would be great, or -
as has been suggested here before - a numerical display at the side
of an optical display or slider.
I also would like a readout for AGC-T since I have the FlexControl set to adjust it.0
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
