Volume and AGC level display
Vincent Martin - N5ATM
Vincent Martin - N5ATM Member ✭✭
edited March 2017 in New Ideas
An idea for a small change to SmartSDR.
To my knowledge, the only way to see the actual slice audio level and AGC level is to hover over the slider control.  While the indicator on the sliders give you an idea, it would be helpful to see the numbers at a glance without having to use the mouse.  I think it would be a good idea to show the numbers constantly, maybe on the left or right side of the respective sliders.
If not a permanent feature, maybe an option?
73 N5ATM
2 votes
In Review · Last Updated
  • Walt - KZ1F
    Walt - KZ1F Member ✭✭
    edited March 2017
    That's essentially my suggestion of abandoning graphic meter indication altogether. As far as green, yellow, red, for overdriving, change the color of the numeric. One can actually see the amount of screen real estate it would save.
  • DH2ID
    DH2ID Member ✭✭✭
    edited December 2016
    An option to change from graphic to numerical would be great, or -
    as has been suggested here before - a numerical display at the side
    of an optical display or slider.
  • KD4HSO
    KD4HSO Member ✭✭
    edited February 2017
    I also would like a readout for AGC-T since I have the FlexControl set to adjust it.
