Is this right? ant1 only or ant2 only for recieve?
Dave Dave
Dave Dave Member ✭✭
I just noticed on my 6300 that I cant use ant1 for one panadapter and ant2 for the other one...
Is this normal?????????  I can use different xmit ant ok.
  • GI4FZD
    GI4FZD Member
    edited April 2017
    Yes, you only have one receiver in the 6300, if you want to do that you need the 6700.
    cheers
    Paul
  • Jon_KF2E
    Jon_KF2E Member ✭✭✭
    edited July 2018
    The 6300 and 6500 each have only one SCU. Since the SCU digitizes the antenna input and there is only one, you can only connect one antenna at a time. You can have multiple slice receivers on each band and two(6300) or four(6500) panadapters. The 6700 has two SCUs so it can connect two antennas. Because it can connect two antennas the 6700 can also do diversity reception.
    Jon...kf2e
