CW Skimmer & SDR Bridge startup problem
Steve Belcak
I just updated to a new SSDrive and a fresh install of Win 10 Pro (working well). I then installed CW Skimmer and SDR Bridge, all the latest versions....in my old Win 8 setup, I could start SDR and Skimmer would start automatically......for some reason this is not happening with my new install.....I can start SDR Bridge, then start Skimmer and they work well.
Anyone have an idea of what I'm missing so that Skimmer starts as part of the SDR startup process....like it did in Win 8?
Steve
Flex 6500
Steve
Flex 6500
A Telnet problem would prevent a connection between these programs.
Don't know about Win10 and Telnet, as I will not install Win10 and stay with my
working Win7 system :-)
73, Alex DH2ID
If it is a missing telnet client, you can install it easily enough.
https://www.rootusers.com/how-to-enable-the-telnet-client-in-windows-10/
Thanks for the advice...actually, CW Skimmer and SDR Bridge work just fine. My issue is I have to start each individually when in the past, if I started SDR Bridge, CW Skimmer would start up as well. I'm trying make that work again.
73, Steve K3WKM0 -
You probably need post this question to SDR-Bridge Support0
- 246 Community Topics
- 488 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 765 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 812 Third-Party Software
