ThumbDV connected to a PC
Mark Erbaugh
Mark Erbaugh Member ✭✭
edited February 2020 in Third-Party Software
Has anyone connected their ThumbDV directly to a PC and got it working? I downloaded the DutchDstar software which appears to be the recommended PC software, but I can't get it to work. The latest non beta version doesn't have an option for ThumbDV and the beta version keeps crashing for me, I've tried both Windows 7 and 10.
  • Bob N7ZO
    Bob N7ZO Member ✭✭
    edited February 2017
    Hi Mark,
    I have used my ThumbDV successfully with Dutch*Star "DV Node for Windows" version 1.5.8 Preview 3.
    Make sure you set the baud rate to 460800 if you have a recent ThumbDV.
    73, Bob, N7ZO
  • Cal  N3CAL
    Cal N3CAL Member ✭✭
    edited March 2017
    Mark I have my ThumbDV working on my Win10 system using the Beta version 1.5.8-3.  It crashed the first time because the baud rate was set to 230400.  Setting it to 460800 should do the trick.
    Cal/N3CAL
  • Mark Erbaugh
    Thanks for the info. The problem was my Baud rate. I'm listening to the International D-Star net of REF 01 C right now.
  • N7BCP
    N7BCP Member ✭✭
    edited July 2017
    Baud rate change fixed my Dutchstar crashes also, thanks.
  • Andrew VK5CV
    Andrew VK5CV Member ✭✭
    Mark,
    I am having trouble with DStar on HF with the 6500 and am trying to test the dongle on WinDV.
    Can you please put up your settings for REF01c?
    I am not getting very far.
    Andrew de VK5CV.
  • Roy Laufer
    Roy Laufer Member ✭✭
    I have tried to get it to work on my boutique shop Windows 7 system (yes, the latest version of WinDV, and I checked that the ThumbDV is plugged into the PC). The window opens up and locks up. It uses about 6-7 % of my CPU cycles doing nothing visible until I close the window.
    Any thoughts?
  • Mark Erbaugh
    edited October 2015
    I was getting lockups when I had the ThumbDV baud set to 230400. Setting it to 460800 fixed things for me. If you look on the NWDigitalRadio website it says that the Rev A version of the ThumbDV next 460800.
  • Mark Erbaugh
    edited October 2015
    Under Options:
    Callsign: N8ME, cake sign suffix letter blank.
    Auth Call: blank
    Enable Slow Mode: not checked
    Enable Logging: not checked
    Call Lig Size 100
    Callsign Server AA4RC
    RF Device: ThumbDV, COM3 460800 baud
    Callsign N8ME / <blank> LOCL
    Under Settings: just the defaults
  • Roy Laufer
    edited October 2015
    I tried both 460800 AND 230400 using the device manager... No joy!
  • Mark Erbaugh
    edited October 2015
    The baud rate needs to be set in WinDV.
  • Bob N7ZO
    Bob N7ZO Member ✭✭
    edited December 2016
  • Roy Laufer
    edited May 2017
    Thank you, Mark and Bob.
    One of the problems was that I couldn't get to the Program Options window in the first place  - the program would lock up on the initial window!
    Removing WinDV and re-installing accomplished nothing. I had to uninstall it and then comb thru the registry, with regedit.exe for any entry of "MicroWalt" and delete them, then re-install WinDV!
    On my Windows 10 laptop, the driver did not default to VCP mode and it had to be enabled by me, then it chose to use a comm port already in use by Smart SDR CAT! After much "twiddling" I got all the settings straight and it seems to work on my Windows 10 laptop (no traffic on the Repeater when I tried it, so I am not 100% sure, but it looks good). I wasn't ready to reboot the big desktop and clear its comm port confusion (it so far doesn't recognize the ThumbDV's comm port, but that be fixed by a reboot...)
    I don't know how anyone would have figured this out if they hadn't monkeyed around with Windows system for the past 30 years....
    It goes to show, it's always something!
    Roy, AC2GS
