router info
elan
is this Router will work with the 6700 ?
http://www.amazon.co.uk/NETGEAR-EX6200-100UKS-802-11ac-Gigabit-Extender/dp/B00J33SZXY/ref=sr_1_14?s=...
73 elan
73 elan
That's a wifi range extender you want a router. The extender is a WiFi repeater. Router has dhcp among other features that deal with IP distribution. Is your goal to extend your WiFi range, add ports to your cable provider connection? Or establish a network in your house where ip distribution is handled by a device other than your PC? All with or without WiFi. If you already have an internet provider that provides a means of hooking up you PC for intent it probably already has extra ports which will act as a switch, router, dhcp serrver and probably has WiFi. If no WiFi then you can a WiFi adapter. Introducing more than 1 dhcp server or router to a network is complex for the average person. Stay away from that if you already have one provided by your internet provider. flex does not support statically defined IP address...it requires something that it can broadcast dhcp to to get an ipadress. The simlpiest way is with a router like this (again bearing you don't already have one) http://www.amazon.co.uk/RT-AC3200-Tri-Band-Wireless-Broadband-Download/dp/B00Y2NVH4O/ref=sr_1_10?s=computers&ie=UTF8&qid=1444994229&sr=1-10&keywords=router1
hi
yes i have but it is poor made by BT , the one you show me is way over ****
i do not see a point to buy one i do not think i have all the use of it any way
the one i post was in question .
thank you any way
please see the link of the poor router i have http://www.shop.bt.com/products/bt-home-hub-5-068343-90RY.html0 -
sorry you are correct , i was pointing to this one sorry
http://www.amazon.co.uk/dp/B00AKD407Q/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=1GGGBPUPYQ5Z...
thank you0 -
as well i look on this one ,what one is the better to go http://www.amazon.co.uk/R7000-100UKS-Nighthawk-Wireless-Beamforming-Downstream/dp/B00HDK4GAK/ref=sr_...
73 elan g0uut
The last two are good options however, I am never a fan of wireless routers without external antennas. Those with internal antennas never seem to get the reach than those with external antennas.
I do want to point out, your current router is more than sufficient to operate the flex. I have never measured more than 2 or 3 Mb/s using my 6300... If it works.. I would just keep it... If its defective then thats a different story.
thank you for the info Mike
good weekend now
73 elan g0uut0 -
Moderators should remove this before someone clicks on the link.0
- 657 The Flea Market
- 438 SmartSDR for Mac
- 203 DAX
- 385 SmartSDR API
- 52 Aurora
- 295 FLEX-8000 Signature Series
- 969 Maestro
- 944 Genius Products
- 467 Remote Operation (SmartLink)
- 809 Peripherals & Station Integration
