net connection info
elan
is any one can advise in order to connect the 6000 to my pc i can do that with a internet switch ? i have Netgear GS105 SWITCH , so i can connect it to the switch and the pc , do i need the Router connect as well ? since the router long way from my station i use wireless
that my pc, i am going to become new user of 6700 any info please thank you
73 elan g0uut
73 elan g0uut
Elan,
Connect both your PC and Your Flex to the Netgear Switch, they will then talk to each other. I am old school, and believe that anytime you can get "wire" CAT5 directly to the router, the better off you are. In my home network, I get 50 MB download to computers that are wired, the laptops using wireless only get 30 MB download.
Good Luck.
John
W9KXQ
I agree with John, Elan, if at all possible, use hardwire.
hello John
thank you , well i do not use network at home however i was not sure it is just connecting the switch
the flex and pc hi hi i may later do more if i need i cant see anywhere in the user Manu about how to connect the flex to the pc etc it will be nice to see it .thank you again btw do i need to set any ip address or something like that ?
73 elan0 -
hello Bill
the problem it is long away from my station and i will need a very long CAT5 to do so since i may not use the net when i use the flex since i have other laptop etc ,but for start if i just need the switch and the pc it is good no ?
73 elan g0uut0 -
Elan,
You will need to sent IP Address for both the Flex & the Computer. They need to be in the same subnet (Computer-192/168.1.20, Flex-192.168.1.25 ) 255.255.255.0
Hop this helps.
John
W9KXQ
Netgear GS105 is a switch and needs to be connected to a router via a cable or wireless bridge, I have used wireless bridges and they work fine.
Currently I use a NETGEAR EX6150 connected to the same switch and works perfectly.
Rob
hello Rob
yes interesting thank you for the info i see they sell them on Amazon
elan0 -
Hi Elan
Purchased mine on Amazon four weeks ago, arrived next day, working same evening, perfect connection and really simple setup, all running within 10 minutes.
Rob
hello Rob
thank you it is great info
elan0 -
You can connect the flex and PC directly and use auto-discovery. No internet to the PC that way. You can use a switch, too. You can connect a wifi extender to the switch to give network connectivity to the PC, allow assigned addresses to the devices, and still keep hard-wired goodness between the flex and PC. That's what I do. I also assign fixed DHCP assignments to my rig and computer in case the router connection is interrupted.1
- 339 Community Topics
- 609 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 172 SmartSDR for Maestro and M models
- 405 SmartSDR for Mac
- 265 SmartSDR for iOS
- 248 SmartSDR CAT
- 186 DAX
- 373 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 196 FLEX-8000 Signature Series
- 916 Maestro
- 888 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 746 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 964 Third-Party Software
