Flex 6500 and Acom 600s
Stefano - W2WTZ
I tried with Ddutil, SmartSDR and Omnirig but I can't get communication between 6500 and Acom 600s through RS232. Quite sure it's a problem of configuration/parameters... any idea?
Try a null modem cable0
I used a null modem, but the problem is that 6500 has no CAT, the band data is taken from SSDR through the PC but I don't understand if I have to use SSdr Cat or Ddutil and what is the correct setup.0
If you choose DDUtility the first page allows you to chose flex or legacy radios. That allows Ddutil to select the proper cat commands. And of course you attach this program to the correct. Cat port. Electronic port.
Doing this correctly will display frequency info.
The next pages on the setup give you access to different amps. Watt meters. Etc.
If it is not listed. You will need to create a virtual com port pair and allow the radio to talk with one port and broadcast to the amplifier port again DDUtility allows you to do this. Also commander will also allow this. (Easier in my opinion) There is a detailed how to hook up a om amplifier. Using Ddutil. Here in the community pages. Follow that solution. Just do it with the a com.1 -
utilThanks for suggestions, I searched info on the community but I didn't find any post on this matter... do you have a link? I used DDUtil second page with amp. I will test as you suggest...0
HI
if you whait few week i work on someting based on Rasperry PI
for CAT command and BCD band decoding
but still hope that Flex add FTDI USB cable driver to the radio
and permit true Hardware CAT
D-STAR Dongel already handle it as serial port so it not big deal to Handel CAT
73 Marc L. VE2OLM0 -
yup ,but also handle transverter switcing (IF / PTT) do 10MHz REF distribution
and nice webpage interface ;-)
i use PI LAN for telnet to radio and get VFO frequency and other thing i need
have already do a version last year but now i do V2.0
http://alphatronique.com/forum/viewtopic.php?f=3&t=7
Remote QTH do also lot of nice thing , i really love it rotator interface0 -
The listing here on this is. Om power amps and 6500 It is the next to the last post. With the expected settings. Your 600 shares a similar need. Just follow. Substitute were you have the 600. And it will work. Until something else comes out. This works just fine. It's been 4 years using this and similar radios with no on board com port. And with amps that need com port info0
Yes Marc, I can wait, pls keep me informed... In the meanwhile I will try np2g suggestion.
el problema se resolvió la interfaz? puede manejar 600s ACOM con tubería flexible de 6000?
Gracias por cualquier información
Javi LU5FF
Not me. I don't find a clear and detailed procedure. I thanks np2g for suggestions, but I can't understand it. At the beginning he wrote that I should read frequency. Where? I know that's it's myself limited but without a detailed procedure I don't want to risk my equipment integrity. I hope that in the next SSDR release FRS will interface directly to the more difussed PA hassle free. DDUtil is very nice but supports only few PAs and not Acom 600s. I need a guide for dummies....0
- 338 Community Topics
- 580 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 387 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 366 SmartSDR API
- 9K Radios and Accessories
- 893 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 702 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
