Timer built into flex radio
clint yates
clint yates Member ✭✭
I was wondering g if anyone knows if there is a way to get the flex 6300 to automatically shutdown at a defined time. I use my flex to stream audio .If i want to leave it running and go to bed,I want a way to automatically shut it down.
  • K6OZY
    K6OZY Member ✭✭✭
    edited February 2017
    Shut down the software?  Use a Windows Scheduled task to **** smartsdr.exe at a certain time.
    Shut down the hardware? Use the remote power on connector connected to a relay controlled by an arduino or raspberry pi.
    Any of these solutions are outside of the scope expected by Flex to provide.
  • clint yates
    edited March 2016
    I realize it is beyond the scope of flex but just wanted ideas on shutting the radio off.I am already using windows scheduler for the software
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited February 2018
    Or just put a timer on the power supply to shut off
  • Walt - KZ1F
    Walt - KZ1F Member ✭✭
    edited November 2016
    I would suspect that is a less than optimal solution as you'd likely want the radio (and corresponding software) to shutdown gracefully, e.g. saving state information.
  • Tim - W4TME
    edited December 2016
    Walt is correct.  You want to use the Remote On/Off control to initiate an orderly shut down and power up.
  • KD8TVB
    KD8TVB Member
    edited October 2015
    Wemo maker
  • KC2QMA_John
    KC2QMA_John Member ✭✭
    edited July 2018
    I would be cool to have a timer feature built into SSDR.
