Timer built into flex radio
clint yates
I was wondering g if anyone knows if there is a way to get the flex 6300 to automatically shutdown at a defined time. I use my flex to stream audio .If i want to leave it running and go to bed,I want a way to automatically shut it down.
Shut down the software? Use a Windows Scheduled task to **** smartsdr.exe at a certain time.
Shut down the hardware? Use the remote power on connector connected to a relay controlled by an arduino or raspberry pi.
Any of these solutions are outside of the scope expected by Flex to provide.0 -
I realize it is beyond the scope of flex but just wanted ideas on shutting the radio off.I am already using windows scheduler for the software0
Or just put a timer on the power supply to shut off0
I would suspect that is a less than optimal solution as you'd likely want the radio (and corresponding software) to shutdown gracefully, e.g. saving state information.0
Walt is correct. You want to use the Remote On/Off control to initiate an orderly shut down and power up.0
Wemo maker0
I would be cool to have a timer feature built into SSDR.
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
