pc input
Rich McCabe
Member ✭✭✭
Not sure I understand the purpose of the PC input on the software. Have used mic and balanced and thought maybe I could use a USB mic setup on the PC and select PC. Oddly enough I was still getting some audio through my balanced input even with PC selected. Can someone give me some guidance?
The only time I have used the pc mic selection is running remote using a computer microphone.0
It was designed for use when using remote access via LAN (presently v.1.5) or WAN (in the future, v.2.0).
But it can also be used at times when you may have an alternate audio source from a computer, such as when using PC based audio processing software like Stereo Tool, etc. or if using a bluetooth Headset through your computer.
It is a lower bandwidth audio input that streams from the default playback sound device in windows (or other OS)
Ken - NM9P0 -
Thanks guys. Appreciate it.
- 255 Community Topics
- 491 The Flea Market
- 7.4K Software
- 137 SmartSDR for Maestro and M models
- 333 SmartSDR for Mac
- 241 SmartSDR for iOS
- 225 SmartSDR CAT
- 162 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 789 Maestro
- 42 FlexControl
- 837 FLEX Series (Legacy) Radios
- 737 Genius Products
- 394 Power Genius XL Amplifier
- 256 Tuner Genius XL
- 87 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 119 Contesting
- 588 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 815 Third-Party Software
