pc input
Rich McCabe
Member ✭✭✭
Not sure I understand the purpose of the PC input on the software. Have used mic and balanced and thought maybe I could use a USB mic setup on the PC and select PC. Oddly enough I was still getting some audio through my balanced input even with PC selected. Can someone give me some guidance?
The only time I have used the pc mic selection is running remote using a computer microphone.0
It was designed for use when using remote access via LAN (presently v.1.5) or WAN (in the future, v.2.0).
But it can also be used at times when you may have an alternate audio source from a computer, such as when using PC based audio processing software like Stereo Tool, etc. or if using a bluetooth Headset through your computer.
It is a lower bandwidth audio input that streams from the default playback sound device in windows (or other OS)
Ken - NM9P0 -
Thanks guys. Appreciate it.
- 378 Community Topics
- 117 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
