Logger 32 with Flex 6500
You can use a CAT port to control the rig from the software, using Kenwood protocol. I'm not too familiar with that logger, but if it has TS2000 or TS480 support, it should play.1
Thank you, George. I will try that and reply. Very Best, Jim0
I have used logger32 with my 6300 and currently use it with my 6500. Just use cat and kenwood 2000 option at 38k baud rate. I switch within logger32 between my 6500 and back up ic7400, which I have set up as radio1 and radio2. 73 Steve gw0gei / gw6j0
Thank you, Steve. I currently have the rig control working with FLDIGI. Will this be a problem? Any conflict? 73, Jim0
just set up two different COM ports in CAT, one for each application. It will be fine.1
Thanks, George. Actually, I just had a battle with the Logger 32 upgrade from a very old 3.23 to a version 3.50 but hopefully that is resolved and now I can go on to making it work with the Flex.
BTW, in upgrading Logger 32, the log file page is out of order from what I had. I spent some time trying to find the configuration menu which I had set up a very long time ago but can't seem to find it now. This is the menu with check (tic) marks to select the columns and order of log entries.
As always, I appreciate your help. 73, Jim
Jim - if you are an L32 user you should join the L32 user group : groups.yahoo.com/hamlogger and post your configuration question there. The group has 4500 members and the Logger32 author ( K4CY ) is a daily problem solving participant. The group is great for L32 problem solving and there are many Flex PSDR and SSDR users
Right click and then choose set up with a left click (from memory as I am away from shack at present)0
Thank you, All. I did figure it out finally. Steve was right on the money. I will also check in with that L32 group but for now that is solved. On to my next issue but I will start another thread for that. 73, Jim0
- 113 SmartSDR+
- 920 Genius Products
