rtty audio problem
jim
using flex 6500, version 1.5. In rtty mode I do not hear the audio of the signal that I'm copying. What am I doing wrong?? Got the operator error.
That is just normal receive audio. Upper right of SSDR display is master audio control for either headset or speakers. There are also audio controls found within the slice control window. If you right click the speaker icon within the slice control window it will mute the slice. Hope that helps.0
Do you have the slice or master volume turned down?0
All audio controls are set as normal. Nothing turned down or muted.
I knew it was operator error, and it was. Thanks for the replys
Jim
If receive audio is normal for all other modes except for rtty, I am at a loss because I do not know what can cause a total loss of audio except the above.0
- 112 SmartSDR+
- 944 Maestro
