rtty audio problem
jim
jim Member ✭✭
using flex 6500, version 1.5. In rtty mode I do not hear the audio of the signal that I'm copying. What am I doing wrong?? Got the operator error.
  • km9r.mike
    km9r.mike Member ✭✭
    edited September 2015
    That is just normal receive audio. Upper right of SSDR display is master audio control for either headset or speakers. There are also audio controls found within the slice control window. If you right click the speaker icon within the slice control window it will mute the slice. Hope that helps.
  • Tim - W4TME
    edited March 2020
    Do you have the slice or master volume turned down?
  • jim
    jim Member ✭✭
    edited May 2016
    All audio controls are set as normal.  Nothing turned down or muted.
  • jim
    jim Member ✭✭
    edited March 2020
    I knew it was operator error, and it was.  Thanks for the replys
    Jim
  • km9r.mike
    km9r.mike Member ✭✭
    If receive audio is normal for all other modes except for rtty, I am at a loss because I do not know what can cause a total loss of audio except the above.
