SmartSDR v1.5.0 is Now Available
Tim - W4TME
edited March 2017 in SmartSDR for Windows
FlexRadio Systems announces the immediate availability of SmartSDR v1.5.0 for the FLEX-6000 Signature Series SDRs which includes the new Wideband Noise Blanker (WNB) to complement the previously enhanced Noise Reduction (NR) and Automatic Notch Filter (ANF).  This release represents the fulfilment of the enhanced noise mitigations features for SmartSDR.  In addition to the WNB, SmartSDR v1.5.0 includes a number of new features, existing feature enhancements and addresses various defects identified in previous versions of SmartSDR for Windows. Please consult the SmartSDR Software User's Guide for details on using the new and updated features of SmartSDR for the most optimal operating experience.
New Wideband Noise Blanker:  SmartSDR now incorporates a totally new class of noise mitigation targeted at correlated impulse noise.  The purpose of WNB is to visually and audibly remove periodic types of noises such as ignition noise, power line noise, electric fence noise and other types of periodic impulse noises.  Operating at a very high sampling rate, it provides a breakthrough in the ability to reduce this type of noise not only inside the receiver passband but across the entire spectral display bandwidth.
RTTY AFSK Mode:  SmartSDR now has a dedicated AFSK digital mode specifically engineered for RTTY operation with third-party digital mode applications, like MMTTY.  Then new RTTY mode is designed for LSB operation where the Slice receiver carrier line is on the RTTY Mark frequency.  One advantage of Mark being on the carrier line is that spotting RTTY signals will send and tune to the actual frequency of the spotted signal. The frequency offset value for Mark and the value for Shift can be set by the user and is Slice receiver specific for operating RTTY at different baud rates in addition to the standard 45.5 baud (2125 offset with a 170 Hz shift) symbol rate.  Within the RX passband filter, there are alignment marks for both Mark and Space tones for optimal signal alignment.  As with other SmartSDR modes, both RIT and XIT are fully supported for RTTY.
DIGx Mode Improvements:  Several improvements have been made to DIGL and DIGU to enhance the operation of digital mode with third-party applications.  They include DIGU/DIGL specific AFSK offsets that allow for the dynamic realignment of the center frequency for preset RX filters and ClickTuning.  When a signal is ClickTuned on the spectrum display, it will tune the Slice receiver to the center of the RX filter.
D-STAR Waveform Mode:  A new waveform has been added that allows users to use D-STAR with the ThumbDV module from NW Digital Radio. With a ThumbDV plugged into the back of the radio and the D-STAR waveform, any 6000 Series radio can now communicate using D-STAR protocol for voice and data. The waveform is bundled with the ThumbDV Waveform GUI client application that control common D-STAR fields and shows decoded D-STAR information to ensure proper operation with repeaters and direct QSOs.
FDX:  As part of our effort to enhance the FLEX-6000 for contest operation, a full duplex (FDX) mode of operation is now supported. Full Duplex will allow you to transmit and receive at the same time, but there are limitations.  The limitations include the possibility of an SCU overload condition that depends on the signal entering into the SCU, signal path isolation inside the radio and additional RF gain provided by the RF preamps.  To operate in FDX mode, you will need a dedicated receiving antenna and the Slice receiver must be on a different frequency from the transmitter.  Please refer to the SmartSDR for Windows Software User's Guide for detailed instructions on how to operate in FDX mode and how to calculate if your transmitted signal will overload the SCU before operating in FDX mode.
CAT Changes to Support SO2R Contesting (FLEX-6700 Only):   SmartSDR Cat has been enhanced to support the Open Two Radio Switching Protocol (OTRSP).  This, along with the new SO2R and OTRSP port types, allows a single FLEX-6700 to operate seamlessly in SO2R mode with logging applications such as N1MM Logger+.  In this configuration, the FLEX-6700 Slice B is configured as the 2nd radio.
Max Power:  A new feature to set the power amplifier’s maximum output has been added.  This feature should be used with high gain PAs to ensure that the maximum driver level is not exceeded while transmitting or using the TUNE function.  This feature is located in the Transmit tab in the Settings->Radio Setup menu.
Improve Frequency Calibration:  For FLEX-6000s that do not utilize a GPSDO, the frequency calibration routine found in the Receive tab in the Settings->Radio Setup menu has undergone significant improvement.  The frequency calibration routine is more accurate and works well when WWV is experiencing atmospheric and Doppler fading.  Frequency accuracy of less than 1Hz may be obtained with an adequately strong WWV signal.  It is recommend that all users without a GPSDO recalibrate your radio using the new frequency calibration routine for optimal radio performance.
FlexControl Improvements:  A significant effort was focused on the operation of the FlexControl for SmartSDR v1.5.0.  The FlexControl detection and data processing logic has been optimized to provide more consistent, reliable, and stable operation.
NOTE: SmartSDR v1.5.0 supports updated waveform module functionality. A new version of FreeDV is required for SmartSDR v1.5.0.  If you had previously installed the FreeDV waveform, you must remove it from your radio and uninstall it from your PC after installing SmartSDR v1.5.  Then download and install the updated FreeDV waveform.  SmartSDR waveforms can downloaded from the Waveforms web page.
SmartSDR for Windows v1.5.0 and the Release Notes can be downloaded for the FlexRadio web site:
SmartSDR for Windows Installer
SmartSDR for Windows v1.5.0 Release Notes
  • Tim - W4TME
    edited March 2017
    SmartSDR for Windows v1.5.0 Changelog
    v1.5.0 2015-09-04
    #2283 D-STAR: TUNE is now properly handled
    #2338 CAT: Fixed stability issues with OTRSP
    #2173 Fixed a UHE related to Slice filter width
    #2328 Slice lock indicator is now correct on startup
    #2099 TXAllowed and InterlockState FlexLib properties are now initialized properly
    #2326 API: References to NB are now WNB.  Old NB references will remain temporarily for compatibility
     v1.4.24 Alpha 2015-08-28
    #2287 RTTY: Added Mark and Space frequency indicators, including when using RIT/XIT
    #2245 D-STAR: Fixed issue where radio speakers would emit a loud sound on keyup
    #2290 Max Power setting now limits the TUNE slider in the same way as the RF slider
    #2310 CAT: Fixed inconsistent behavior between IF and ZZIF commands when SSDR is not running
    #2304 Fixed a radio crash when changing VFOs
    #2288 Added 60m to Netherlands
     v1.4.23 Alpha 2015-08-21
    #2182 Remote: Fixed long startup freeze/pause of SmartSDR when using Remote is enabled for some users
    #2185 Message now appears when the set max power level is set too low for ATU usage
    #2262 Fixed DIGx click-tune behavior when multiple Slices are present
    #2143 NB indicator on Panadapter now appears correctly when multiple Panadapters are being used
    #2112 FM post-demod default filter width to 200-4500 Hz
    #2187 RTTY: Changing shift now properly realigns filters if the shift goes beyond the filter
    #2255 RTTY Mark/Shift and DIGx offsets now added to Memory form
    #2280 Renamed 137 Band to "2200" and renamed 474 band to "630"
    #2285 6300: Fixed an issue that caused low or no power when using CW above around 80 Watts
    #2278 FDX: Fixed audio pops when using TUNE with FDX enabled
    #2241 API: Added RFGain field to FlexLib Slice class
     v1.4.22 Alpha 2015-08-14
    #2213 Made further improvements to how the Noise Blanker behaves
    #2224 Fixed Global Profiles saving/loading (broken from v1.4.21)
    #2097 FlexControl: Fixed an issue that could cause the FlexControl to not be detected
    #2186 API: Fixed xmit command response codes
    #2203 API: Removing a meter now correctly removes subscriptions for it
    #2229 API: RF PreAmp can be be change from the Slice level
     v1.4.21 Alpha 2015-08-07
    #2213 Made improvements to Noise Blanker
    #1097 Added D-STAR waveform mode for use with ThumbDV Dongle
    #2097 FlexControl: Initial detection is now more reliable
    #2153 FDX now works properly on initial TX when Slice is in CW mode
    #2189 CAT: Fixed ZZFI and ZZFJ commands for setting filters in DIGx modes
    #2170 Fixed text rendering issues when using the Windows Classic Theme
     v1.4.20 Alpha 2015-07-31
    #2149 CAT: Added RTTY mode
    #2184 Full Duplex audio now works on the same band as long as the RX and TX antennas are not the same
    #2160 Frequency Error calibration routine now more accurate and reliable
    #1119 Added a max power level for TX
    #2171 Fixed a radio crash when loading global profiles with RTTY values
    #2127 Modified DIGx filter offset behavior
    #2093 Slice lock is now remembered in band persistence
    #2153 SmartSDR FDX button state is now recalled correctly at startup
    #1958 API: Fixed issues with using Radio.ProfileDisplaySelection with Global Profiles in FlexLib
     v1.4.19 Alpha 2015-07-24
    #2149 Added RTTY mode and DIGx mode offsets for easier tuning in digital modes
    #2097 Improved FlexControl detection
    #2150 Mic gain slider now only affects Windows mic level when PC is selected as the mic input
     v1.4.18 Alpha 2015-07-17
    #2122 Added Full Duplex capability for all radios when using different bands
    #2013 Adjusted Noise Blanker for better behavior
    #2123 Added a NB indicator on the Panadapter when NB is enabled
    #2131 FlexControl window now correctly reflects detection of FlexControl
    #2107 TX Out-of-band interlock now gets updated when changing the Slice TX filter
     v1.4.17 Alpha 2015-07-10
    #2013 Improved Noise Blanker
    #2095 Fixed a radio crash while using NR/ANF
    #2087 FM: Post demod filters in DFM are now 0-5500 Hz to allow digital SAT operation
    #2087 FM: Transmit filters can now be changed
