Inexpensive GPS reference???
Output drive levels can be adjusted from +7-dBm to +13.3-dBm 10MHz
Looks interesting.
Dave, WB5NHL
It isn't the jitter or accuracy that you should be concerned about, it the phase noise you have to be mindful of.0
Jitter is the integral of phase noise. Jitter should be a concern since ADC clock jitter determines the noise floor, especially at VHF, but I assume Flex is using the 10 MHz input to discipline the TCXO/OCXO via a narrow loop bandwidth? At least I hope so; that's where schematics would be helpful to see what oscillator and clock synth you are using. What's the jitter of the 6500 vs 6700 since the latter is an OCXO? The phase noise/jitter far outside that loop bandwidth won't affect system clock jitter, so stability and accuracy is the primary concern, hence the GPS.
That phase noise is similar to my Z3805A at 10 kHz.....but they ought to show the phase noise below 10 Hz. That's where TCXO begin to **** out and OCXO are much better, at least 20-30 dB lower. For $260 you can get a Z3805A or equivalent on eBay with a double oven OCXO. At 100 Hz the (linked above) unit has -120 dBc/Hz whereas the Z3805A is -135 dBc/Hz.
This the the same Chinese vendor I bought mine from (got it in two days). A suitable supply can be bought from Mouser for $30.
http://www.ebay.com/itm/HP-Z3805A-GPS-Frequency-Time-Receiver-10-Mhz-1PPS-/271938525721?hash=item3f5...0 -
N5AC mentioned in another thread that the loop bandwidth for the eternal 10 MHz reference circuit was 10 Hz, so phase noise under 10 Hz offset will be that off the external reference. This is where the OCXO based GPSDO are much better than the TCXO based GPSDO. So probably better getting a good, used unit with OCXO.
Ha ha, now look at this. The Chinese acquired a bunch of surplus OCXO and are building GPSDO around them for $150. Notice they don't give phase noise specs:
http://www.ebay.com/itm/10MHZ-OUTPUT-SINE-WAVE-GPS-DISCiPLINED-CLOCK-GPSDO-GPS-Antenna-Power-supply-...
I lived in western Germany (JO31) and that's one of the busiest areas of ham populous in the world.
Huge HF signals from contesters and clubs and massive VHF signals from across EU.
I used a variety of 10 MHz sources driving HF radios and transverters for VHF-SHF.
What I found was that anything like the DEMI LO boards with PN in the 70-80 dBc/Hz range you can throw away in high signal situations - outcome .. multiple rx images, terrible CW signals with non T5 notes, poor rx sensitivity and awful tx performance even further out from your carrier.
I swopped to a Kuhne TR144 transverter and LO's using Kuhne PLL's that have close in performance in excess of 150 dBc/Hz and no more problems, especially using radios with +40 IP's and the TR144 front ends.
My results show that a half decent GPSDO that has a PN over 110 dBc/Hz will be fine ... and that anything 120 upwards you can sleep well and your neighbours will be fine. Close in you're unlikely to be any issue on the band unless you are a KHz away from a contester using multiple KW's and he's more likely to be a problem if he's using an older radio too - older icom kenwood yaesu radios have terrible phase noise!
my GPSDO has
@10 Hz - 105 dBc
Steer clear of non spec'd PN figures but you will find it nigh on impossible to tell in the real world of the GPSDO has PN of 120 or 150!
@100 Hz - 125 dBc
@1 kHz - 140 dBc
My findings based on real world results ... not lab spec'd measurements!
Cheers
Simon ZL4PLM
I just saw another GPS disciplined TCXO from a hackaday project here
https://hackaday.io/project/6872-gps-disciplined-tcxo
He has it available here
https://www.tindie.com/products/nsayer/gps-disciplined-ocxo/
He shows some pahese noise plots also for it
Wim... I don't see his phase noise plots. Can you point me to them, please (sorry... yes, I did look at both links).
I'm curious to compare the phase noise in his $250 TXCO-based unit with that of my Jackson Labs Fury.
Peter
K1PGV
I think I took the Allan plots for the phase noise plots, but isn't the phase noise
just determined by the DOT050V tcxo he's using
datasheet is here with phase noise details
http://www.conwin.com/datasheets/tx/tx395.pdf
> isn't the phase noise just determined by the DOT050V tcxo he's using
Thanks Wim. I guess we know that the phase noise won't be better than that of the device he's using, that's for sure ;-)
Looks like a pretty steep curve. I see -100dBc at 10Hz and -130dBc at 100Hz,and at 1K the chip's down near -150dBc... that all seems pretty good for such an inexpensive device.
Simon (ZL4PLM)'s post seems to indicate that this level of performance is probably good enough. What do folks think? I'm trying to educate myself a bit more on this whole topic.
Peter
K1PGV
-150 at 1 KHz is more than adequate ...
One follow-up if I may: In terms of receiver performance, do the close-in noise figures (such as -100dBc at 10Hz) not matter? Sorry to be ignorant (in the true sense of the word), but I would think that if the Phase Noise is greater than the MDS this would affect receiver sensitivity. Or am totally off-base here? Thanks for helping to school me on this (I'm a pretty good software engineer, but not much of an RF EE).0
@ -100 at 10 Hz probably not - but -70 @ 1 KHz for sure!
and yes poor LO phase noise also affects rx performance too .. it affects MDS, IP etc ... on transverters with really poor phase noise in the LO you can end up with images and rough sounding recovered signals and poor rx performance ... so all round its a bad deal
- 338 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 171 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 248 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 19 Aurora
- 191 FLEX-8000 Signature Series
- 913 Maestro
- 887 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 742 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 956 Third-Party Software
