fldigi - Rig Control can't see Device (Com Port from CAT)
Nick
I had fldigi running perfectly prior to Windows 10 upgrade. Now I try to set up the rig control and it doesn't see any of the com ports. I've reinstalled SDR to catch up on all the drivers and reinstalled fldigi and the XML file. CAT appears to work correctly by providing the default COM 4. but fldigi doesn't see the port. I get no rig control or frequency info in fldigi. DAX works fine and I can even transmit if I key manually on the SDR screen. Am I missing something? Tnx
Did you uninstall all Flex software, including VSP, before upgrading? If not, go ahead and do so, removing drivers when asked. Reboot, make sure no ghost "hidden" ports exist in Device Manager, then reinstall. Good luck!0
yes, completely uninstalled Flex S/W. I had the same config on my laptop and have the same results on it.
added into: Went to device manager and com 4 is listed as having problems. tried to repair and got this error Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19). tried to search for driver and it couldn't be found. Any ideas?
I was researching virual ports for Linux when I came across something that may be applicable . there was an issue with bad ftdi drivers. It may not be applicable in your case but something to check. It could be a software install sequencing issue and you have bad drivers. Not so much bad drivers per se but a change to the specs which manifests as bad drivers.0
Nick delete all those comp ports reboot computer.... then reload SSDR and reboot again and that should solve your com port issues...Then go into FLdigi and choose the correct com port and initiallize.... I had the same issue when I upgraded to win 10...
Nick - does it work with other programs other than Fldigi?0
- 109 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
