Radio not releasing session
Walt - KZ1F
Flex 6500
SSDR/Radio software 1.4.16GA
Client UI: FRS SmartSDR
Summary: Radio is not releasing session to SSDR
Initial symptom: Radio would not transmit
Narrative:
Initialization progresses normally up to the point command client udpport 4991 is issued. This command is never acknowledged, i.e.
C25|client udpport 4991
R25|0 <---- this never occurs
All prior commands are acknowledged.
SSDR starts and fails to show a panadapter.
Requesting a new panadapter in SSDR fails.
Stopping and restarting SSDR shows radio "in use <same host machine>"
Stopping and starting the radio clears this and in discovery dialog radio shows Available.
Initialization proceeds normally until 'client updport 4991" is issued.
Other status messages flow normally, for instance GPS status.
Actions Taken:
1) restart SSDR
2) reboot radio
3) reboot radio after shutdown, multi-minute power down.
At one point, eventually (it didn't happen right away) SSDR issued message that connection was lost to the radio, please reconnect. Upon doing so radio showed as in use.
Unable to export profiles.
It appears to work, status transitions to "exporting" then eventually back to 'export'.
Nothing was exported.
Prior to this discovery effort initial symptom was transmit, more precisely tune, failed.
Immediate conclusion: It does not appear radio responds properly to a lost TCP connection. I'd look there first. Yes, I understand the bulk of the traffic is UDP, but since there is no UDP connection, per se, the loss of the tcp connection should signal the absence of the UDP client and trigger reset activity in the radio.
Narrative:
Actions Taken:
1) restart SSDR
2) reboot radio
Walt, Firewall updates have caused issues exactly like that, not passing UDP ports for SmartSDR. Has your firewall/anti-virus updated recently? May need to make exceptions for SmartSDR. Also don't forget about performing the full reset, but check the firewall first0
Walt,
Does this happen every time? If not, is there a sequence of events that tends to make it happen more often?0 -
@Dudley - not a firewall issue as I did perform a factory reset, the first and only one I've done in the two years I've had the radio.
@Eric - yes, each and every time until I gathered all the trace info and walked through the startup logic, then did the factory reset.
Again, first symptom was the radio would not transmit upon a tune action.
It appears to work OK now.
So while I cannot give you reproducible steps, I thought it might be informative to check what the radio does when the TCP connection is dropped, i.e. onCancel() or whatever .net calls the unexpectedly terminated session action.0 -
Thanks for the info. We will take this into consideration when we work in this section of the code.0
Eric/Tim - I consider this answered so you guys can close it. Thanks, Walt0
RR0
- 379 Community Topics
- 631 The Flea Market
- 123 SmartSDR+
- 193 DAX
- 39 Aurora
- 948 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
