recording audio in the 6300
clint yates
i am trying to record my transmit audio to audacity. does anyone know how to do that? recording the receive is no problem. I have the 6300.
Its done the same way, if you start recording then transmit, it will record your out going audio.0
i am talking about the program Audacity, it is a 3rd party audio program. it doesnt record my tx audio but does record the rx audio.cant figure out how to make it see the tx audio.0
I haven't found a way to do it yet. As a work-around, I use my USB Mixer with my Heil PR22 mike and record with Audacity from the USB Mixer audio channel. I record it with the mixer flat. Then I use the Compression effect to gently compress and level the audio and export the audio as a .WAV file into my Contest Program's audio directory. (I use N1MM+) All the major equalizing and processing is done on the Flex 6500 itself.
This works in a pinch until such time as FRS implements the ability to record and save TX audio to a file.
Ken - NM9P
Thx ken,I couldn't find a way to do it . But your workaround is something I will try0
I was recently trying to do this, to no avail. I"m looking to record or capture my SSDR screen with the transmitted audio audible when I play back the video. I can hear my transmitted digital tones by capturing the audio from DAX TX 1 . Is there no way to do this from our Mic ? I could swear I have seen videos demonstrating a Flex where the transmitted audio is captured. Maybe I am missing something simple.
Andy K3UK0 -
Use the DAX Mic Stream Audio - it is connected to the TX audio channel.
It will send either the MIC audio, or the audio you are sending to the transmitter via the DAX TX Audio channel. It won't do both at the same time. But it will do one or the other. If you leave DAX ON, then it may not send your live MIC audio.
Caveat: The audio you get from MIC Stream is PRE-filter/EQ/PROC. So it will NOT sound exactly like your transmitted signal.
I don't know if this changed in a recent release or not. I haven't checked it for a while.
Ken - NM9P0 -
I thought i tried that yesterday with no success... but will go back and try again.
Andy K3UK0 -
If you are using OBS to capture video & audio, OBS has two audio input channels...
Set one to DAX MIC Stream. Set the other to DAX RX of the slice channel you are receiving. (Be sure to activate the proper DAX channels in the DAX Control panel and select a DAX channel in the RX slice.)
I will test this out again this evening. I haven't done it in a while.....0
- 375 Community Topics
- 105 SmartSDR+
- 425 SmartSDR for Mac
