Getting closer!!!!
James Whiteway
Slowly getting there on building a Panadapter and one day soon, a Panafall !
james
(oh, it's not too pretty right now, but, it works!)
james
2
Hello James,
I appreciate a lot your work and your results.
If I am not wrong this is the first panadapter that is using the official FlexLibs. Really great.
I hope you can go on with your panadapter and I would suggest you to add some kind of "cluster spot" feature.
GL & 73' Enzo
iw7dmh0 -
Thank you Enzo for the kind words. I have learned a lot working with Flexlib. But, I still have a long way to go. I have you, Eric, Stu, William, Walt and many others to thank for help and guidence. Eric found out why I was not getting any data flow. Once that happened, things started to click. I will keep your suggestion in mind.
WD5GWY0
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
