The ability to explicitly assign sound devices
Norm - W7CK
I have a lot of sound devices on the computer I run SmartSDR on. Many programs will only use the "default" sound device while others have the ability to assign a specific sound device to their application. It would be really nice if SmartSDR had the ability to use any playback and recording sound devices and not require them to be assigned as the default devices.
Norm, I use this little program
http://audioswit.ch/er
which lives in the task bar. You can switch audio devices to default with it. I need it only for EasyPAL, as SmartSDR itself does not need default sound devices only. I use Audacity to record and can assign DAX RX/TX to it, although they are not the default sound devices. If you, for example, want to play back sound to a ham, who wants to hear his modulation, just click DAX and MOX and PLAYBACK on Audacity and you'll output the recorded signal.0 -
Thanks Alex. I really don't want to be clicking on anything or loading anything every time I want to use a different device. As an example, I may want to have music or OS sound to come out of the main speakers and have SmartSDR in the Remote mode coming out of my USB headset or maybe my wireless headset with boom mic. I often use a wireless headset with SmartSDR in Remote but like to have other sound coming out of the computer speakers. The ability to use specific sound devices should really be built into the SmartSDR software - then it is seamless and versatile.
Norm0 -
I understand that, Norm, but this is a Windows problem.
Windows was, and regrettably still is, an OS which was
primarily designed for EDV, not multimedia. I look forward to SmartSDR being ported by someone to OS X :-)0 -
I’ll vote for that!!!0
Prior to my Flex, I used a Signalink USB with HRD. I was able to tell HRD to use the Signalink and was able to listen to my music through the desktop speakers. I don't believe this is a PROBLEM with windows and I get sort of tired of people dissing windows and telling folks OS X is the fix for everything. Now if you want to promote Linux, I'm game.0
Ok, Linux is great 8-)0
- 389 Community Topics
- 53 Aurora
- 970 Maestro
- 944 Genius Products
- 307 Shack Infrastructure
