Windows 10 Release thread for problems, bugs and solutions with Flex software and associated program
Hi everybody,
as Windows 10 Release becomes available, I would like to suggest that we create a
Windows 10 thread here, where all problems, bugs and solutions can be collected
concerning SmartSDR, SmarSDR CAT and DAX compatibility, but also problems
with software and drivers used with SmartSDR.
Problems with PowerSDR and it's firewire driver should also be included.
73, Alex DH2ID
73, Alex DH2ID
I agree with this too. Not expecting too many issues but still good to have our observations and resolutions all kept in one place.0
Working in the IT field for over 30 years, I would suggest you make a backup of your system first prior to going to Windows 10. I myself, I'm going to wait till Flex certifies SmartSDR with Win 10 first.0
Yes there is no rush, Win 7 will be just fine for some time still.1
I strongly disagree with the single post for multiple problems approach. You really need to start individual posts for specific issues. A long rambling thread with multiple topics, issues and sub topics is not useful for community members looking for help. I receive this feedback all the time where the useful nugget of information is buried at the bottom of a 80 reply post, so please adopt this suggestion for making the information provided easier to consume. Thanks.9
PowerSDR is running fine on Windows 10 here this morning (Flex-3000) Very easy setup, actually no setup needed other than to click OK a few times. Full import of all programs and files (yes I backed up first anyway). If you have Win7, 8.0 or 8.1 it's free. de KK8ZZ
It is well advised to wait a while before upgrading to Windows 10. Microsoft products are known to have issues at launch.0
Ok, Tim, I understand the reasons for your comment.
Maybe there will be a Flex tutorial on Windows 10 when we have
squashed all the bugs :-)
73, Alex DH2ID0 -
I know of nothing really different about Win10 that is OS specific with SmartSDR at this time. I have been running it on the Technical Previews for some time now without any problems except after the updates where the drivers stop working. Hopefully that will be all we experience (fingers crossed).1
Had updated couple of days ago on the final release of Win10 what registered for me right now like FOC
no visible issues in any appl. for the moment0 -
Likewise. Working fine. No observed issues with SSDR.0
Had some odd issues with ssdr after upgrading to Win10 (dax errors, and page faults with portctl.sys). Uninstalled/reinstalled and a few reboots, and the problems seemed to clear up.
Now I gotta get Cortana to figure out which microphone to use, i think it's trying to use one of the dax audio devices.0 -
How do you wind up getting Windows 10?0
I got it here: http://www.microsoft.com/en-us/software-download/windows10
When I ran the app, it gave me the option of creating a .ISO file, or to just upgrade my computer to Windows 10. I chose the upgrade option. It was somewhat painless, but I did need to uninstall my Cisco VPN client, and also Symantec anti-virus which it told me was incompatible with Windows 10 (until symantec updates it).
Someone I work with had to revert back to 8.1 temporarily to resolve a network issue (vpn conflict). The downgrade only took about 10 minutes. Sounds like it keeps the old version of windows for about a month before deleting it to free up space. This is 2nd hand knowledge though, I haven't confirmed that info anywhere.0 -
Just completed Win10 install. Everything good on 6300 with initial installation except for DAX driver.1
there is a a windows.old version kept on the disk0
had the same DAX problem ... is there a workaround on this other than unloading and reloading - was a clean install for SSDR0
I also had DAX problems with HRD, FLDIGI and WSJTX. I reverted back to 8.1. All is fine now.
My choice: because I use fldigi, I decided to revert back until Flex has a new DAX driver for Win10. You've got a month to revert back after you install Win10. Here is the how-to: http://www.howtogeek.com/220723/how-to-uninstall-windows-10-and-downgrade-to-windows-7-or-8.1/0
Joe - we are not planning a new DAX driver for Windows 10. The current one is working fine. The problem is how Windows 10 handles the upgrade from a previous operating systems. This is nothing new with Windows operating systems.
If you are having issues. I strongly recommend that you consider using the procedure I posted yesdterda that describes how to completely uninstall the SmartSDR ecosystem of software before you upgrade and then re-install afterwards. The same goes for any other applications you had difficulty with.
https://helpdesk.flexradio.com/hc/en-us/articles/204975589-How-to-do-a-Complete-uninstall-of-SmartSD...
I got crazy and let Windows 10 install this morning. (Had recently done a backup so no worries there) Only issue found so far is that my FlexControl is dead. (PowerSDR and other software are running perfectly) I could see it in Device Manager but it would not respond. Uninstalled it from Device Manager, disconnected it, waited a minute, reconnected. got a nice window telling me the driver was being installed, and then it reappeared in Device Manager as a serial port device. No improvement though...
Playing with this again after getting home tonight. FlexControl was assigned to Com3. Still not working even though Device Manager shows it as "working properly" and the three LED's all turned on when I booted up the computer.
Just for the heck of it I tried changing the Com port used by the FlexControl from 3 to 5. Still no life however. Port settings are 9600 8N1 No Handshaking. In the FlexControl window in PowerSDR the Auto Detect box IS checked.
Last thing to try was to uninstall everything and start over. So I uninstalled PowerSDR, uninstalled the FlexControl driver, disconnected the FlexControl, rebooted, re-installed PowerSDR and verified it works, shut it down then re-connected the FlexControl. Its driver re-installed "apparently" normally, but STILL PowerSDR will not do anything when I spin the wheel or push a button.
Any ideas?
Joel, VE6EI0 -
I have tried this several times and still no DAX, everything else seems fine.
After hours of fun with the uninstall-Win10, clean install-SSDR process Tim outlined, I got it all to work, DAX included, after restoring the SmartCAT Available Flex Virtual Ports entry. Fldigi is up and running. Win10 is in, and all is good again.1
If you are having issues. I strongly recommend that you consider using the procedure I posted previously that describes how to completely uninstall the SmartSDR ecosystem of software before you upgrade and then re-install afterwards. The same goes for any other applications you had difficulty with. https://helpdesk.flexradio.com/hc/en-us/articles/204975589-How-to-do-a-Complete-uninstall-of-SmartSD....0
I am closing this post because the recommendation to start a new topic for issues rather using than single post for multiple problems was not taken.
- 318 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 157 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 125 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 699 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 923 Third-Party Software
