Disable and bypass the 6000 series final amplifier via sortware or hardware for QRP?
Stan VA7NF
Member ✭✭✭
There have been discussions about the current draw when biasing the 6000 final amplifier, see https://community.flexradio.com/flexradio/topics/current-drain-on-6300?topic-reply-list%5Bsettings%5... for one.
Does, or can, the final amplifier be bypassed and not keyed up on transmit? The preference would be via an API call from SmartSDR Tx setup, or by a physical process such as removing the final and jumpering connectors.
Last FD we ran 3AB with (literally) a ton of batteries but the Flex was left behind due to exceeding the current budget of 7A for rig, computer and monitor(s).
It would be nice to flip a switch on SmartSDR (or Maestro) to turn on/off QRP reducing the associated battery draw.
I may be wrong here but I would think just reducing the power down to QRP levels would do the same thing.0
The finals are class AB and draw an estimated 5A just for bias, then add the power out. If the driver can be routed to the antenna switching then it becomes a super QRP rig that will draw around 2A rather than the current 7A.0
I've gotten mine down to less than 4 watts. The guy at the other end asked me to increase it again because he was no longer copying me well enough. (SWR 1:1).
My amp, on standby, has a input power meter.
Buy a Flex 1500...very good QRP radio... Available used for $500 give or take a bit.0
My amp also has a power meter when it's not on standby. HI ;-)
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
