Looking for Proper Flex 1500 frequency calibration for 2.7.2, TX is off 30khz off.
Marc Hessel
you can calibrate via WWV using the onboard calibration menu or if you have a 10Mhz gps stable source. Click setup then calibration. Is only the tx off or is the rx off as well ? Read the manual on how to calibrate the rig.0
Make sure XIT is not enabled too. 30 KHz is a lot to be off0
OK Seem ti have found it Calibration...rather simple tune to WWV start calibration....drop width to zero and as Tim states disable XIT...Thanks Gents as always....I accidently calibrated to 28.3800, does it need to be on any particular mode or just WWV on AM..0
The radio will switch to the proper mode when you select to run the test. All you need is a known frequency standard and a strong signal (S7 or better)0
- 382 Community Topics
- 632 The Flea Market
- 123 SmartSDR+
- 195 DAX
- 40 Aurora
- 953 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
