Error in KV decoder, or no KV decoder present
YV5WZ
I installed WSJT-X new 1.5 ....Now I get a message every single minute "Error in KV decoder, or no KV decoder present" ..I have uninstalled and reinstalled 3 times......same error message
George
YV5WZ
George
YV5WZ
You may want to check the WSJT Yahoo group for support; this is not likely a Flex issue. The KVASD install does require a license agreement, and for Mac OS, some terminal commands. You may need Administrative permissions in Windows and/or installing the software outside the "usual" Program Files folder.0
I agree. WSJT 1.5 works for me on SSDR so I would start looking at WSJT and Windows.0
I had the same problem installing WSJT-X on my Flex 1500. After trying everything suggested on the internet, I found the solution. Create an empty file named KVAST.BAT and place it in the in directory where you installed the WSJT-X executable.
Rick
K3IND
Wonderful Solution.....!!!! I did......and ....It really works!!
Thanks!!
George
YV5WZ0 -
Your solution only tells WSJT-X that there is an executable whereas in my wsjtxin folder lives kvasd.exe. It was downloaded during installation
of WSJT-X 1.5.
In Jim Taylor's words it is
...an implementation of the the Koetter-Vardy algebraic soft-decision decoder for the Reed Solomon (63,12) code....
A word about the Reed–Solomon error correction here:
https://en.wikipedia.org/wiki/Reed%E2%80%93Solomon_error_correction
I have it and run it. To see whether it improves decoding I really should
do a double-blind test with and without it :-)
73, Alex DH2ID0 -
Quick update - the server hosting the KV Decoder went down, so the installation of a new version would fail. Once the download is available again (it is not included in the WSJTX distribution), installation should work normally.0
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
