Default EQ Settings
KY6LA_Howard
KY6LA_Howard Member ✭✭✭
edited June 2020 in New Ideas
My Friend Janny ON5PO asked a Question about the Automatic Settings for EQ
"Une question ,est-il possible ,d’avoir le changement automatique RX/TX du EQ
quand je suis en RX il reste en RX ,quand je passe en TX, il sera en TX
est-il prévu cette position
Janny
ON5PO, Specia Janny (Giovanni)"
In other words is it possible to have EQ display change AUTOMATICALLY from RX to TX when you transmit and return to RX when you receive.  This would greatly simplify setting TX profiles.
Yes I understand that you could click the mouse and be in TX but this just makes it easier.
Frankly its a good idea  - So I am posting it as an idea
2 votes
In Review · Last Updated
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited July 2015
    I second that suggestion. Sounds like it would not be hard to modify software-wise and make it much nicer for on-the-air testing. Thank you for that suggestion.
    Jim, K6QE
  • DV
    DV Member ✭✭
    edited July 2015
    I also agree.  Perhaps in the next release?
  • Peter Bentley
    Peter Bentley Member ✭✭
    edited July 2015
    Yes, good common sense idea, thank you
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited June 2020
    I wish that RX EQ were persistent with mode, so that I could have a SSB RX EQ, and another one for CW, and another for AM.
  • Jim Gilliam
    edited July 2015
    Another excellent idea!
    Jim, K6QE
