Default EQ Settings
KY6LA_Howard
Member ✭✭✭
My Friend Janny ON5PO asked a Question about the Automatic Settings for EQ
In other words is it possible to have EQ display change AUTOMATICALLY from RX to TX when you transmit and return to RX when you receive. This would greatly simplify setting TX profiles.
Yes I understand that you could click the mouse and be in TX but this just makes it easier.
Frankly its a good idea - So I am posting it as an idea
"Une question ,est-il possible ,d’avoir le changement automatique RX/TX du EQ
quand je suis en RX il reste en RX ,quand je passe en TX, il sera en TX
est-il prévu cette position
Janny
ON5PO, Specia Janny (Giovanni)"In other words is it possible to have EQ display change AUTOMATICALLY from RX to TX when you transmit and return to RX when you receive. This would greatly simplify setting TX profiles.
2
I second that suggestion. Sounds like it would not be hard to modify software-wise and make it much nicer for on-the-air testing. Thank you for that suggestion.
Jim, K6QE
I also agree. Perhaps in the next release?
Yes, good common sense idea, thank you0
I wish that RX EQ were persistent with mode, so that I could have a SSB RX EQ, and another one for CW, and another for AM.2
Another excellent idea!
Jim, K6QE
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
