flexradio 1500 switch tx rx noise
ik5sre
Hello,
i'm novice with flex radio 1500,i buy it on ebay used. I have a problem when switch tx / rx a noise on my display. This is the video where you can see the problem
https://youtu.be/2YY13m7Bf0c
Sorry for my bad english. My flex 1500 n. si 1312-2266
I had already reset to default factory the flex 1500,use another pc with windows 7 and XP,use a different usb cable,but i have always the problem. Perhaps this is a hardware problem? rele'?
Thank you
73 de Ik5sre Francesco
Thank you
Try this again with nothing connected to radio other than antenna, it may be feed back from something. No mic nothing connected..0
Also I see you have the AGC-T set at 73, try bringing it down to around 50 to 45, the radio will be easy on the ears and you can still hear signals. And you can turn on AVG to slow the signals down on the panadaptor, better for your eyes. Then go into setup and adjust the rate speed for that as you like it. Just a few operating hints.0
Francesco,
Looking at your video, you do have the receiver at 5 kHz wide, the tone is part of transition from TX to RX, but the tone is at the DC crossing or IF of the radio. Either you can narrow your receive passband or you can move that crossing.. The setting is the IF in the DDS window of PowerSDR setup -> General -> Hardware Config .. Move 3800 to 5100 to take it out of your passband.. Unfortunately this also will move the centerline of the radio in the Panadapter , as you will notice that the centerline when zoomed in all the way will move slightly to the right.. Kind of a cause and effect with the 1500 and USB.
thank you,i already try it but i have again the noise.
try another mode ? Does this happen in all modes ?
i have the same problem also when i move to another band (10,15,20 m...) this happen when the rele' switch
what happens when you use ssb mode and you click ptt and speak ?
the same thing,when i turn by tx to rx i have this noise,this happen with the mic,with cw key and also when i move by a band to another,.When the internal rele' switch.
You may have to have it fixed, nothing seems to help.0
It looks like you are zoomed in on the waterfall display. Click on the 0.5x button below the waterfall display and can you make another video when you key the microphone on ssb and cw ? Also, what version software are you using ? please show us the whole screen if you can0
Everybody needs to pause for a moment. This is NOT A PROBLEM. This is normal for the FLEX-1500. This is the DC "noise (0 Hz IF) being nulled by the wide band image rejection (WBIR). The default DDS offset for the FLEX-1500 is 3850 Hz below the carrier (LSB). Please take note of the comments by Dudley as his description on how to move the DDS offset to a greater value so that it is outside of the RX passband filter.1
ok thank you for information, i'm happy if this is not a problem,i'm novice with flexradio.
Just wondering why the 1500 would have this problem unless the previous user fiddled with it Tim ?
No problem, Francesco0
This isn't a problem ;-)
The issue is only an issue on LSB or AM where the RX filter is wider than the maximum TX filter for a 1500 (3800 Hz). Since the 1500 can only show 38 kHz of spectrum, we moved the DDS offset on the 1500 so that the receiver carrier line was more centered in the panadapter, rather than being shifted down by 9 kHz as it is with the 3000 and 5000. By moving it 3850 Hz, it is outside of the maximum TX bandwidth of 3800 Hz
Based on the video, the DDS offset is exactly where I would expect it to be with the default setting at ~ 4 kHz0 -
I see it on mine. Its 9Khz down on lsb
In Setup Menu, Hardware Config, click in Expert DDS frame, and in IF(Hz) change Flex IF frequencie, probably yours config is 0Hz and SR button is selected. Change to maximum value. In Flex5000 defaul is 9000Hz anda maximum is 20000. In my Flex5000 if I put 0 hertz in this box and press SR button, when I release PTT have same behavior your Flex1500 no mater BW TX is.0
thank you to all comunity for the help.
Is it ok now?
- 342 Community Topics
- 612 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 407 SmartSDR for Mac
- 266 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 374 SmartSDR API
- 9.2K Radios and Accessories
- 20 Aurora
- 199 FLEX-8000 Signature Series
- 919 Maestro
- 890 Genius Products
- 452 Power Genius XL Amplifier
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 748 Peripherals & Station Integration
- 138 Amateur Radio Interests
- 971 Third-Party Software
