Make the icons for SmartSDR, CAT, and DAX different colors or images.
edited May 2020 in SmartSDR for Windows
They're hard to find at a glance.    And why do CAT and DAX both minimize to the task bar and a tray icon?   They should just be tray icons rather than creating more task bar clutter.
Welcome!
  • Member ✭✭
    edited September 2018
    I like this idea.
    Jeff, N3VE
  • Member ✭✭✭
    edited July 2015
    This has been proposed several times. I even offered to do the icon art myself.
  • Member ✭✭
    edited July 2016
    Can't tell you how many times I've clicked on the wrong icon. At least there's a 50/50 chance.
  • Member ✭✭
    edited May 2020
    Surely you mean a 1 in 3 chance? The SDR, CAT and DAX icons are all 95% identical with very slight differences. A nasty trick from a grown-up software house.
  • Member ✭✭✭
    edited March 2017
    Hi Drax,
    George / KF2T suggested the color idea 2 years ago.  It has 12 votes so far.  Adding more votes may help move it up in the priority.
    https://community.flexradio.com/flexradio/topics/unique_icons
    Regards, Al / NN4ZZ
    al (at) nn4zz (dot) com
  • Member
    edited July 2015
    It's the biggest easy win Flex could do!
  • Member ✭✭✭
    edited July 2015
    brilliant
  • Member ✭✭
    edited April 2016
    I am somewhat vision impaired, and these are easy to see.
  • Member
    edited July 2015
    Not sure if they work for the colorblind.   7% of males are colorblind.  They need to be visually different too.
  • Member ✭✭✭
    edited December 2016
    but I hope we can all read?
  • Member ✭✭
    edited July 2015
    I agree that CAT should be in the system tray only. It's a configuration item, not something you need to access often. It just takes up room on the taskbar.
  • Member ✭✭✭
    edited January 2017
    You obviously do not operetta remotely. The tiny icons in the system tray are almost impossible to access
  • Member ✭✭✭
    edited November 2016
    Often programs have choices for the VI, and sometimes multiple themes of icons.
    I'd add to this good suggestion that the larger desktop icons always include the version number.
    Steve K9ZW
  • Member ✭✭
    edited February 2018
    There should be a link to DAX and CAT from inside SSDR.
    Also, there should be DAX and CAT should default to connect to the most recently selected radio selected from SSDDR.
    Also, the sky should always be blue and the outside temperature should always stay between 50°F and 90°F.
  • Administrator, FlexRadio Employee admin
    I agree.
    Also, please drop the upper temp limit to 85F with a 50 degree dewpoint. ;-)
  • Member ✭✭✭
    edited July 2015
    In Arizona, we water freezes at 85F.  :)
  • Member ✭✭✭
    edited July 2015
    Please raise the lower temperature limit to 68F (DAY and NITE)... too many years of freezing my **** off in Canada to ever want to feel cold (anything below 68F) again...
  • Member ✭✭✭
    Getting old Howard?
  • Member ✭✭✭
    edited July 2015
    Yup... If you ask My grandkids they will tell you i am at least 100
    OTOH... just upgraded my Tesla order to the new one with "Ludicrous Mode"
    http://www.teslamotors.com/blog/three-dog-day
    So I must have confidence that my reflexes are still young enough to control it.
