Panadapter running 2 meters often goes dead
Norm - W7CK
I'm not exactly sure what the process is that leads up to this problems but the panadapter running 2 meter slices often goes dead. No signals and very low noise floor. To wake it up, I grab the panadpater with the left mouse button and move it back and forth horizontally. The panadapter then wakes up and everything appears back to normal.
Is this a known bug or just something I'm experiencing alone.
I see something like that as well but a bit different, the band does not go dead. The band at times on the second pan will sound like its off freq or a second tone in with the signal. All I need to do is change the mode to USB and back to LSB and the problem is gone. Not sure this is related or if can be repeated but, I thought I would toss this out there.0
Do you feel it is related to being on 2m or just you've seen it there as that is where you tend to hang out? I've seen that and I don't even go on 2m. That's why I ask if you feel confident it is unique to 2m.
Nope, I don't have 2m setup yet so, it has nothing to do with it.0
Thanks but I meant Norm.0
I can have 4 panadapters open and the 2 meter one is the only one that seems to go dead. I just grab it with the mouse, move it back and forth a bit and it starts working again. STRANGE.....
I create multiple HF panadapters and then a single 2 meter panadapter and add a slice or 2 to each one. I then save this profile. At the end of the day, I shut down the rig. The next time I turn the rig back on and start SmartSDR, it OFTEN starts with the 2 meter panadapter dead. I grab the panadapter with the mouse, move it a bit and it starts working.
I'm trying my best to find the combination of events that reproduce the problem more consistently, but haven't quite got it yet.
Is anyone else experiencing this?
This can very often be reproduced when I create a Profile that includes a 2m panadapter and a couple HF panadapters. I then load a HF only profile then go back and load the one that includes 2 meters. The 2m panadapter is often dead and I have to grab it with the mouse move it back and forth to wake it up.
If I have a profile with 2m along with HF panadapters that I am using, then shutdown the Flex, reopen the software. It often starts with 2m dead.
IS ANYONE ELSE WITH A 6700 EXPERIENCING THIS?
You have said the magic words; mixing 2m and HF panadapters. There is a know issue with switching Nyquist zones in the radio and how the antenna is assigned and it's interaction with band level persistence. This is referenced in the release notes. The workaround is to manually set up 2m first on the XVTR port and then create HF panadapters which are in a different Nyquist zone.0
TIM - I've done that and I'm able to create HF panadapters which are in different Nyquist zones. That part works fine and I've saved a couple profiles set up like this. What I'm experiencing is when I recall one of these profiles it occasionally loads with the 2m panadapter dead. The HF one is fine. I grab the 2m panadapter and move it back and forth and it always wakes up. The problem is intermittent but just wandering if anyone else has experienced this.
Please export your profiles and send them to me in e-mail. Tell me which profile is causing the issue so I can try and reproduce it here in the lab.0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
- 456 Remote Operation (SmartLink)
