PTT via Front Panel Mic Connector Stopped Working
K9DUR
K9DUR Member ✭✭
PTT via front panel microphone connector is not working.
I normally use a footswitch connected to the rear panel jack for PTT.  However, while getting ready to take my FLEX-6700 to a hamfest for a demo, I connected the FHM-1 hand mic that came with the radio & found that PTT would not work.  An ohmmeter check of the microphone showed that it was okay.  I did a reset to factory defaults & that did not help.
Radio:  FLEX-6700, s/n 1713-3011-6700-4673
HW Version:  v1.4.16.63
SmartSDR v1.4.16
Help!
73, Ray, K9DUR
  • Army Curtis
    Army Curtis Member ✭✭
    edited January 2017
    Hi Ray.
    As I'm sure you already know, the chances are extremely good the problem is external to the radio, in spite of what your ohm meter is telling you. I would suggest you try a simple wire directly into the front panel mike jack to see if you can key PTT that way. At least it will confirm if the problem is internal or external to the radio.
    Hope this helps.
    73, Army AE5P
  • K9DUR
    K9DUR Member ✭✭
    edited September 2016
    Army,
    No, definitely internal to radio.  Shorting pins 5 & 6 does not activate PTT.
    73, Ray, K9DUR
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited June 2020
    Here's my dumb question....Does the front panel PTT depend upon which mike input is selected on the TX panel?  i.e. mic, bal, line, PC, etc?  I can't remember.
  • Duane_AC5AA
    Duane_AC5AA Member ✭✭✭
    edited May 2018
    Another question is have you ever used the front panel switch input before, or was this the first time?
  • K9DUR
    K9DUR Member ✭✭
    Duane, yes, it has worked before. -- 73, Ray, K9DUR
  • Duane_AC5AA
    edited December 2016
    Ouch.
  • Steve K9ZW
    Steve K9ZW Member ✭✭✭
    edited March 2017
    Helpdesk Ticket time?
    Steve
    K9ZW
  • K9DUR
    K9DUR Member ✭✭
    Already done.  RMA to be issued soon.
  • caravanken
    caravanken Member
    edited July 2015
    I know i had the same thing happen to me and I finally figured out I was out of band that we can legally transmit in. I bumped the tuner.  Just a thought.
    W0KRD
  • John n0snx
    John n0snx Member
    edited July 2015
    Make sure it's not an operator error before you go thru the trouble of sending it in... My guess is something is askew with a setting somewhere....  I have done it many times ... pulled my hair out and then go OH DOH!!!!... That was dumb...Been there done that...
