Permanent keyboard mapping for togglng Transmit / Receive
Jay -- N0FB
Is there a way to permanently configure a key on the keyboard to Transmit and Receive? When running remote LAN, once that you hit MOX you can simply hit the space bar to toggle MOX on/off. The problem is that if you touch any other button control on the screen, the space bar will toggle the last control modified. If there is no way to map a key permanently to toggle Tx/Rx, consider this a request for enhancement. Thanks in advance for your responses and consideration. N0FB - Jay Burgherr
Jay
With DDUtil you can create a macro that will assert MOX and assign it to function key(s) or even toggle it on/off with the same key. If you dont want to use one of the F keys. you could probably remap any other key Ctrl,Shift,Alt + a key to send the F key assignment using a custom key macro with AutoIt. or use AutoIt to send a mouse click to the macro button in DDUtil. I know that the DDUtil macro buttons can do it. I just haven't tried creating either an AutoIt or AutoHotKey script to actually send the keypress or mouse click for PTT/MOX yet. it should be easy enough to setup though. It may even be possible with AutoIt to send the CAT command string directly to a COM port. If you don't want DDUtil in the mix. But that's also something I've never tried do yet. Flexlib API can be used to do this. It's definitely possible. Maybe someone knows an easier way. If no one else has a easier/better way, I'll give my way a serious attempt and post a solution for you in this thread. ZZTX1; turns MOX on, ZZTX0; turns MOX off.
It's added to my TODO list officially now, Im suprised I've never gotten around to it yet.
73, Jay - NO5J
You can also use FRStack.
FRStack provides a host of features to enhance your FR-6XXX experience.
FRStack communicates directly to the Radio using the FlexAPI therefore does not require CAT.
Mark
Thanks! A much easier and better way, Now why didn't that occur to me first. Probably something weird is wrong wIth my brain
. Jay, you might like FRStacks if you've never tried it. A lot of useful, essential really, features all rolled up into one small program, and it doesn't use CAT. It also handles the permanent key assignment.
Actually, I use an AutoIt script to launch all the accessory programs I associate with SmartSDR. That script loads FRStacks, DDUtil, DXlabs, etc. When it sees SmartSDR start, and when SmartSDR closes it closes all the associated programs. It minimizes a lot of mouse clicking and taskbar button chasing on my multi screen desktop. I was thinking I could just add the keypress reassignment to that script. which would have been easy for me to do. But might have been hard for everyone else. And thanks to FRStacks it's completely unnecessary.
73, Jay - NO5J0 -
Thanks everyone. I'm going to try FRStack. I still would love for there to be a native solution.0
I wish most of FRStacks was native.
73 - NO5J0
- 657 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 295 FLEX-8000 Signature Series
- 969 Maestro
- 943 Genius Products
