SmartSDR v1.4.16 Available Now
Tim - W4TME
Administrator, FlexRadio Employee admin
In a continuing effort of product quality improvement, FlexRadio Systems announces the availability of SmartSDR for Windows version 1.4.16 for immediate download. SmartSDR v1.4.16 is a maintenance release that corrects several defects from previous releases. This maintenance release does not include any new features. Please review the SmartSDR for Windows change log for a listing of all changes that can now be displayed at the end of the software installation process. For the optimal FLEX-6000 operating experience, FlexRadio Systems recommends installing SmartSDR v1.4.16 at your earliest convenience. Please note that being a maintenance release, an updated version of SmartSDR for Windows documentation will not accompany this release.
The SmartSDR for Windows v1.4.16 installer and Release Notes are available free of charge from the FlexRadio Systems Downloads web page.
v1.4.16 2015-06-26
#2090 CW: Asymmetric CW filter now updates after a CW pitch change (from v1.4.15)
#2088 CW: Asymmetric CW filter now updates when switching between CWU and CWL (from v1.4.15)
v1.4.15 Alpha 2015-06-23
#953 CW: The carrier (0 Hz) is now the stopping point for the low side of the CW filter
#2079 CAT: Fixed a UHE
v1.4.14 Alpha 2015-06-19
#1755 Fixed issues with setting XVTR from a third party program
#1978 The TX Slice is now properly assigned on a band change
#2050 ANF and NR settings are now properly saved and restored
#2074 SB monitor now works with a hardware PTT while the DAX monitor is also enabled
#2068 CAT: Fixed UHE when RIT is used on a Slice other than Slice A or B
v1.4.13 Alpha 2015-06-12
#1685 FlexControl: Fixed a UHE when using the FlexControl
#2042 CAT: Fixed an UHE when using CAT
#2043 CAT: Fixed an UHE when loading CAT
#2014 CAT: FDV mode is now handled correctly
#2016 FDV: Fixed waveform not showing up the Waveform Manager
#2045 Fixed profile import/export not working (from v1.4.12)
#2032 Fixed an UHE when starting a 2nd instance of SmartSDR
#2013 API: Changed status update type 'monitor' to 'sb_monitor' and removed 'monitor_enabled'
v1.4.12 Alpha 2015-05-22
#1803 Fixed momentary freezes in SmartSDR when DAX TX is enabled
#1906 Fixed an issue that caused SmartSDR to startup without a Panadapter or Slice
#1277 DIV: DAX channel selection is now allowed on a diversity child
#2024 Slice audio pan L/R controls now move through the center rather than jumping to full L or R
#2030 API: removed stray 'atu' tokens from atu status messages
3
- 389 Community Topics
- 53 Aurora
- 970 Maestro
- 944 Genius Products
- 307 Shack Infrastructure
