CW (KY cmd) in HRD / DM780 won't stop in send mode
Edmondo Conetta
Hello all
I'm just setting up a Flex 5000a for our club and everything works perfectly, except one little issue. The issue was fixed before I formatted the computer but I don't recall what I changed.
Here's the problem
VSPE with
COM 9 => COM 10 => COM 11 CAT port for POWER SDR (9) / HRD (10)and CW Skimmer (11)
COM 7 => COM 8 => PTT POWER SDR and DM780
VAC 1 and 2 properly configured
The issue is only when running DM780 in CW - KY
If I send a macro in an DIGITAL mode, the moment that I presso STOP (F5), the TX will stop right away.
If I send a macro in CW - KY , the moment that I presso stop (F5), the TX will continue till the entire message is sent.
In program options
MODE + IDs = PTT checked and unchecked (same issue)
PTT via Serial Port Com 8 (with and withour DTR and RTS, same issue)
As I mentioned earlier, I had the same issue on a previuos configuration (before messing everything around) and I was able to fix it. After I decided to wipe everyhing and restart the setup......without aby backup :-(
Any help, any suggestion?
Edmondo
Here's the problem
VSPE with
In program options
Edmondo
My suggestion would be to post this in the HRD forum:
http://forums.hrdsoftwarellc.com/index.php
I am a HRD beta-tester myself, but can't help you there, because I use a
WinKeyer, not the KY command.
I can only surmise that the whole CW string has to be sent, before you can stop the transmission. Which HRD version have you got? Version 6 has an "Abort" button. Have you tried that?
Now I'm off to Friedrichshafen for the Ham Radio to study at the SDRA,
the "Software Defined Radio Academy". Wish me luck for a mortarboard ;-)
Alex DH2ID1 -
Edmundo,
RTTY data is created and encoded in software external to the Flex hardware and is thus interruptible by the software. A CW KY string of data is set to the FLex as ASIC characters, buffered, and converted to CW in the FLex and can not be interrupted once the message has left the software. This is a problem common to other radios that use CW via the KY CAT command..
AL, K0VM
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 256 SmartSDR CAT
- 942 Maestro
