DDUtil cable for ACOM 2000A
Bill Turner
I am using a Flex 6300. I see in the DDUtil help pages that a special cable is required between the PC com port and the ACOM 2000A com port. Is this cable available commercially or is it a homebrew-only job?
Thanks.
they are commercially available. Check what connections IE male / Female and go for it. Sometimes you do need in addition to a normal RS232 cable a Null modem adaptor for one end. Or a null modem cable . All available on the internet . in various lengths. But if you wish a simple set of connectors DB9's and some wire usually you need only 3 wires and you too can brag about your solder ability .0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
