SmartSDR, Remember Remote, Local
Bob - W7KWS -
Bob - W7KWS - Member ✭✭
edited February 2018 in New Ideas
I'm using SmartSDR on two computers, one next to my 6300 & the other, a Windows tablet, by my easy chair in the family room. They both work great. It would convient if each PC remembered its own place, "Remote" or "not Remote". As it is now, in 1.4.11, the radio seems to remember this setting without regard to which PC is currently connnected. I have to change the setting every time I switch locations. I hope that this makes sense. Thanks, Bob, W7KWS
2 votes
In Review · Last Updated
  • David
    David Member ✭✭
    edited March 2017
    What parts are you thinking should device unique verses shared with all devices?
  • Bob - G3WKW
    Bob - G3WKW Member ✭✭
    edited June 2015
    Yes I have sat puzzling why my speakers were not working till I noticed the Remote button lit up.
  • Bob - G3WKW
    edited June 2015
  • David
    David Member ✭✭
    edited March 2017
    That makes sense to be device unique settings. I primarily use it in remote mode even when next to the Flex and only use one device with it currently so I could not think on specific items. Here are some others now that you gave a starting point that probably make sense as well independent of being remote or local the connected devices are different and intended use of the connecting PC.
    - Remote button
    - Mic selection (PC, Mic, Bal, Line, ACC)
    - TX mic preset
    - EQ settings (Off/On - TX/RX)
    - DAX
  • Bob - W7KWS -
    Good start. Thanks for the additional items! Any more?
