Amps for 1500 from ebay
Marty Bluhm
I am looking at adding an amp to my 1500 for when going gets rough. I've seen a lot of amps on ebay for the kx3,703, etc. Has anyone used one of these with the 1500 and what was the outcome?
Thanks and 73
Marty
W8AKS
Thanks and 73
Marty
W8AKS
2
I'm using an RM Italy amp with my 1500. It's ok but an Elecraft KPXA100 would be much nicer (possibility of a built in tuner & covers 6 meters). There are a lot of people using a 50 watt kit, I've forgotten the name at the moment, but the reports are good. The now defunct Tokyo Hi-Power company used to produce a 45 watt amp but they are out of business and some have reported that they've inadvertently destroyed theirs when paired with a 1500. I'd check on that before pursuing the Tokyo Hi-Power.
I use a Chinese MX-P50M from eBay. I get good signal reports and the output is fairly clean, you just have to remember to change bands manually. To key the amp I use a home brew interface using a relay, plugged into the Flexwire socket.
Daphne G7ENA
depends what power you want to run. There are some good solid state amps out there which will give you 50w + output. If you want to run full legal limit, then you would have to choose a amp with tubes which has high gain, but 5w to 1500w is HIGH GAIN.
http://www.w8ji.com/rm_hla-150_test.htm
Read this article before you purchase a RM Italy amp.
It has known, proven, IMD issues. Couple that with the 1500 that also has IMD problems at 5 watts, and you'll have more problems. There are cleaner amps and SDR radios out there. The issue with the 1500 can be controlled by running less power.(3 watts or less)
Better to get a good amp like a TenTec or get a Flex 3000. 100 clean watts. Good signal reports don't tell you if you're radiating spurious signals up and down the band from your signal. Only a spectrum analyzer will show that. Be a good neighbor and try to transmit as clean a signal as you can.
WD5GWY0 -
A couple of links to a review and some test results:
https://vk2qr.wordpress.com/2014/11/25/mx-p50m-hf-amplifier-review/
http://gm4slv-geek.blogspot.co.uk/2015/03/mx-p50m-amplifier-for-ft817.html
Daphne0 -
Hi,
The 50W kit is the Hardrock-50. more info here:
http://www.hobbypcb.com/products/hardrock-50-hf-power-amp
160-6m, 50W with less than 5W drive, built-in tuner available, FCC Type Accepted, USB connection supported in PowerSDR for automatic band switching. Responsive USA support team.
It's also a good physical match for the 1500 since it's the same width and if the rubber feet are in the right places it'll sit nicely atop the Flex.
I'll be happy to answer any questions that you might have.
Jim WA2EUJ
Regarding the IMD issues, these can largely be alleviated by running on the lower power setting of the amplifier. I believe this topic is outlined in the document James refers to above. This provides about 40 to 50 watts out which I've found to be quite adequate. Perhaps the best point about the RM Italy amplifiers is that they are quite inexpensive on eBay. Clearly there are other 100 watt amplifiers of better quality available; most notably, the Ten Tec and the Elecraft units.
This might be an interesting amplifier. $229 is more than a used RM Italy HLA-150 but perhaps the IMD performance is better. On the other hand, an Elecraft KPA500 would put out 175 watts with 5 watts in and that would be a rather significant boost. The comments made elsewhere about the 1500's lackluster IMD performance might make one consider whether such a choice would lead to QRM on the bands. But expanding one's horizons like this leads to a consideration of the possibility of a very clean 12 watt Flex 6100 which might or might not be introduced. Personally, I would wait a few months to see if such a device is forthcoming then make an amplifier choice after seeing what's up next on the Flex stage.0
12 watts into a KPA500 would produce something on the order of 250 to 300 watts out. For simple people, such as myself, this would be quite a suitable arrangement.0
While I'm advocating for 12 watts output, I would like to mention that 5 watts, which the 1500 produces, is not enough to tune the KAT500 auto tuner. 12 watts is certainly enough to tune the KAT500. A worthy benchmark, if I might say so.0
The Hardrock 50 would be cheaper, and a much cleaner solution than the RM Italy HLA series of amps. And the cost would be cheaper too. More so, if all you wanted was 40-50 watts out. Besides, the temptation to drive the HLA amp might not be so easy to pass up! That's why I passed up several deals on HLA 150's and 350's, when I gave serious thought to the same thing for my 1500 when I had it. But, reading closely everything I could find regarding that combination, convinced me that it was not money well spent. And inconsiderant of other Amateur operators. So, I used the 1500 at 3 watts both SSB & CW and had a blast with it. So much so, that I bought a 6300 and sold the 1500. james WD5GWY0
Marty,
I just sold my 1500 and bought a 6300. I have an as new RM Italy HLA-350 Plus available if your interested.
Yes, interested, email w8aks55@gmail.com with the particulars. Thanks & 73 Marty
Tim, if you look up the number posted for the RM Italy amp you posted you will find it is an application number, not a FCC Certification number. It has not been approved yet. They (RM Italy) are being deceptive using that number saying it has been approved when the FCC database says it has not.0
Ahhhhh. Thanks for the info.0
A KPA500 is looking better every day (or the Flex kilowatt amp that is rumored to be forthcoming.)
The KPA500 is a very good amp with good IMD numbers. Well made too. james WD5GWY0
Yes, Elecraft makes quality products.0
In the for what it's worth category, I saw an earlier comment that said it depends on what you want to output . At HamCom this past weekend, I saw a Expert Linear 1.3KFA output 1.5K with 5watts (1.2K @ 2-3 watts). Granted, this is another price range but as stated, it depends what you want to output. I would like to see them do a 500W version in a corresponding package size. This would be a perfect DXpedition size.
Mike, NA5U
I believe someone posted one of those 50W portable amps on QTH.COM yesterday. I just tried to search their site to get the details to post here but there seems to be intermittent access/browser issues with QTH.COM currently (keeps throwing 403 errors).0
Mike, was that 25 dB of RF gain accomplished with an internal modification to the SPE 1.3KFA (e.g., bypassing a resistive RF input pad?)
In the U.S., Part 97.317(a)(2) limits gain from a commercially-manufactured external RF amplifier to no more than 15 dB.
Paul, W9AC
Paul,
I don't know. Glenn, W0GJ and I were being shown this by Bob Hardie, W5UQ. We what it would output with a 2 to 3 and 5watt drive and that what we saw. You might contact Bob for the details. It was an impressive amp but pricey.
Mike, NA5U
I have heard a couple of HLA-150s on the air with 1500's in my rag 80/40 rag chew group. In practical use, they seem to be fairly clean up to about 80-90 watts out, but after that they get nasty-dirty pretty quickly, just as W8JI has reported in his article. By "fairly clean" I mean that there were no visible spurious sidebands generated on my 6500 screen. Yet when over the limit, the "trash" started to rise on either side of the transmit passband pretty quickly. Coupled with a second amp to reach 800-1200 Watts, it could get bad really quickly, so it was essential that the user implemented an automatic power output control such as the utility on DDUtil in order to "keep the neighbors happy!"
Ken - NM9P0 -
- 352 Community Topics
- 615 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 412 SmartSDR for Mac
- 267 SmartSDR for iOS
- 250 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 22 Aurora
- 212 FLEX-8000 Signature Series
- 922 Maestro
- 895 Genius Products
- 324 Tuner Genius XL
- 116 Antenna Genius
- 284 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 974 Third-Party Software
