Metering API - S Meter, ALC, TX Power etc.
Steve Scoggins
Is there a way when you setup a slice to specify which metering data gets send back via UDP?
Specifically we need the following:
S Meter Level
ALC Level
TX RF Power Out
I see the use of the following in Radio.cs
SendCommand("sub meter all");
Thanks Steve N9HE
S Meter Level
ALC Level
TX RF Power Out
Thanks Steve N9HE
from http://wiki.flexradio.com/index.php?title=TCP/IP_sub#SUB_METER
SUB METERSubscribe to a specific meter. The list of meters must be obtained first by selecting the Meter List command and obtaining a list of meters.
C[D]<seq_number>|sub meter <meter_id> <meter_id> = the identifier of the meter
Example:
C19|sub meter 1
See Response Format for details on the format of the response messages from the radio
Responses Hex Response Message Debug Output / Meaning 00000000
Successfully subscribed to the meterResponse Example:
R19|0||
[edit]
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 61 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
