Flex 6500 in 50 Mhz?
Javi LU5FF
Javi LU5FF Member ✭✭
Flex 6500 in 50 Mhz? Hi folks I'm trying to change my platform to Flex 7500, my main activity is concentrated in 50 Mhz, which can give me an opinion about it? the receiver is good in 6m with weak signals? greetings and thanks 73s Javi LU5FF
  • Tim - W4TME
    edited March 2017
    The FLEX-6500 receiver is excellent good on 6m (50 MHz).  I worked EA8DBM (IL18) from FM05 and had no problem hearing him when his signal was 54 with a lot of QRN.
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited June 2020
    Receiver noise figure has never been a limiting factor on six meters at my location. It seems to be pretty sensitive here, and noise always rises when the antenna is switched inline, indicating that it is more than adequate. That may change with a new antenna and noise reduction at my QTH, but I doubt it.
  • George KF2T
    George KF2T Member ✭✭✭
    edited February 2019
    Add another "very satisfied" vote. 50 MHz performance is very good. As with Ken, my limiting noise is external.
  • Bob Brown - N8OB
    edited February 2018
    I have been having a great time on 6M with the 6300
  • Javi LU5FF
    edited January 2016
    tnx all, some tests to eliminate line noise? NB is effective in these cases?
