Problem when opening 2M slice, all other open slices change to match 2M slice?
If I change one to another band it becomes unpredictable if it will work as expected or if it will cause other bands to reset to the same band. The 2 M band will not always stay on 2 meters, majority of the time it too switches.
There does not appear to be a reliable way to select 2 Meters and not have it affect the other slices that are open.
Single slice mode, operation appears to act normal.
This problem existed with the previous software update as well; I was hoping the 1.43 version would fix it. I have not tried the latest version due to some of the other reported issues. New Memory functions work well on 2 Meters.
Suggestions/recommendation welcome!
Watts
K4QJZ
System configuration
Flex 6700 Signature
Flex software 1.43
Apple Macintosh OS 10.9.5 (DESKTOP, 2009)
Dual Quad Cores
16G Memory
100G solid state Boot Drive (60 G to Windows) (4 Terabyte additional internal Storage)
Apple optional High-end video card (2 G memory)
Dual Monitors
Running in Direct Boot mode into Windows 7 Pro 64 bit (7.6 windows system speed test.)
(Same issue if running Parallel version 10 but less main memory available and slower)
Hard wire Gigabit Ethernet to Hub then to Radio (Hub connected to dedicated port on Router, Gigabit ports. (Wireless or wired same conditions) 35-50 Meg download, 10-25M upload, Comcast.
I get similar results. Windows 7 pro, Flex 6700
Before selecting 2M band
After selection of 2M band on slice A
This is a known issue with the FLEX-6700 related to having one antenna in two Nyquist zones and an interaction with band persistence. This is documented in the Known Issue section of the SmartSDR for Windows Release Notes.0
Any idea if it will be addressed in the next release?
At this time I can't say for certain that either it will or will not be included in the next release.
There is a workaround. Open a new panadapter with a new slice. Put the slice RX/TX on XVTR and then manually enter the 2m frequency.0 -
Thanks for the help, we will try that.
Watts
K4QJZ
Thanks Tim. A while back I did exactly what you said and created a profile with a couple panadapters and slices. The other day I decided to create a new profile and couldn't remember how to do the VHF panadapter. Geez, I'm not really that old yet either!
Tim, Is this issue being addressed in the upcoming release? 2m really is clunky to use especially on a 6700 with 8 slices available.0
I also am experiencing the same 144 mhz issues..
tnx
If you do not see it listed in the release notes, it hasn't been addressed.
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
