6300 Locking up
Bob Brown - N8OB
I was in the middle of a 6M CW QSO when things locked up for 10 seconds. I have had this happen in the past while just listening so I don't believe it has anything to do with RFI. DAX was turned on because I some times use CWF to save my fingers.
Using 6300, latest software. Windows 8.1, 16gb memory the only computer on my home network.
Hi Bob - do you mean "CWX" when you say CWF? If so, you don't need DAX on to use CWX. I found when I was having a lot of these "freezes" that after I disabled DAX (on the DAX control panel), the problem went away. Strangely, it stayed away for a long time after I re-enabled DAX! Tim says they're working on this problem, but try the DAX disable for a bit and see if that helps.
Duane, I meant 'CWX' That is what I get for not paying attention. I will try your suggestion. Thanks0
Bob - this is a known issue and we are working on a fix for the next release of SmartSDR.0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
