Welcome to the FlexRadio Community!  Please review the new Community Rules and other important new Community information on the Message Board.
flex1500 and JT65 Time Loss
                    Mike Jones
                    Member  ✭✭
                    Running PowerSDR 2.7.2, JT65HF, Flexradio 1500, and Windows 7 Professional, 64 bit.  Have system clock synchronized thru Network Time Synchorization which updates every 15 minutes.  Time sync on the PC appears to be very accurate.  When running this configuration, "DT values" on the JT65 screen continue to get longer over time (1.5 - 6 seconds over 24 hours).  The current solution is to "Stop" PowerSDR 2.7.2, and then "Start" it again.  I don't have to reboot or anything, just hit the "Stop" button and then "Start." It seems to reset the clock and all is well for a while.  Is there a solution for this problem?
            Mike,
 I had a problem similar to this using the VAC software from Eugene Muzychenko. I solved it by switching to VB-Cable (free).
 Ed, K0KC0
            Ed. Thanks. I am currently using VAC software from Eugene. I will switch to VB-Cable when I get a chance....Once again, "the devil is in the details."
            Did you "buy" vac? The download has limitations unless you purchase it. I am using it with Dimension 4 time software, much better than Microsoft's time app. And free Keith w7zac0
            Yes. I bought vac.....and am using NetTime 3.14 to time synchronize over ethernet. The time sync software seems to work great.......
- 355 Community Topics
- 619 The Flea Market
- 8K Software
- 15 SmartSDR+
- 6.3K SmartSDR for Windows
- 414 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 221 FLEX-8000 Signature Series
- 927 Maestro
- 900 Genius Products
- 458 Power Genius XL Amplifier
- 325 Tuner Genius XL
- 117 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 980 Third-Party Software
