Maestro "top of display" panadapter info panel
Could the top of display pan adapter info be an optional alternate display for SSDR? Just thinking I am liking the way the Maestro display layout is setup. Less display clutter.. would be nice to have that as an option in SSDR. (kind of like PSDR).
perhaps a collapse option that would revert to that display.... just thinking while typing...0
If I understand you correctly, we expect to do this at some point (not scheduled for first release). We would allow use of Maestro as a control surface for SmartSDR and the display on Maestro would have details about SmartSDR/radio and not be full of panadapters/waterfalls.2
Steve,
Having a FlexRadio control surface using the Maestro would be an incredible addition to the SmartSDR 6000 series. With the Maestro's LAN connectivity as an added plus would make this system reach a new level of operational utility. (I love this kind of 'blue-sky' thinking!).
Ted
NX6C1 -
Hi Steve.. That's awesome but also I just like the layout of the band/slice information on the top rather than following a slice across the screen taking up pan real estate. Seems that was solved for real estate reasons by putting the info on top of the Maestro display.. would be cool if that could be selected as a display option on Smart SDR windows. (Oh FWIW not sure if you got my E-mails but tried to reach out to you a couple times regarding our chat in Visalia.. I am sure you are swamped but if you have a sec would like to move forward on that when possible.. drop me a line :-) )0
Keeping these displays lean and simple with options to show only what is needed is key as we start putting these into contesting environments. Anything you would do to make a smaller display show what was needed will likely also be well received on the computer as well as the Maestro appliance.
From Steve's reply above....We would allow use of Maestro as a control surface for SmartSDR and the display on Maestro would have details about SmartSDR/radio and not be full of panadapters/waterfalls.
This capability is also what I'm looking for. It would be great if Maestro has 2 modes:
- full remote
- control surface only to interact with SSDR
I'd probably use the "control surface" mode a lot than the "full remote" mode. There was also some discussion about a "control surface only" device at the dinner.
I haven't ordered yet and figured I'd wait for more information about the direction and timing before I place an order.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
